Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Oreck Vacuum troubleshooting (by 2 users)
posted by SLBeck on Nov 21, 2007
My Oreck Upright has started spitting out what I want it to suck up. I'm going to try replacing the belt, but someone suggested it is the start of a bigger problem - motor burnout?
How do I replace the belt?  Brush?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by luv 2 vacuum, posted on Apr 15, 2008
my oreck blows out stuff instead of sucking up stuff. this happened after vacuuming a shag carpet
Solution #1
posted on Feb 05, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1307 votes
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Oreck Vacuum troubleshooting:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Filter Queen Cheetah II Ash - MU305 Bagless...
i lost the plug from the main body to the hose and now the...
Vacuums
Vacuum cleaner - plastic fitting at end of hose (machine...
Hoover Floormate H3000 Upright Wet/Dry...
My Floormate tends to dispense, and dispense and dispense...
Hoover U5194-900 Mach5 Multi-Chamber...
My vacuum will run fine for a little bit, but then won't...
Dyson DC07 Bagless Upright Cyclonic Vacuum
I have to hold it at a weird almost fully upright position...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
