Question about Haier HPRD12XC5 Air Conditioner
The fan is blowing water out it is not draining
Fan is blowing water due to Clog Drain pipe or dirty evaporator
Posted on Jul 26, 2009
Does a bosch fridge freezer always have water in the evaporation tray?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
It is normal to have water in your evaporator drain pan.
Your refrigerator goes through a defrost cycle every 8-10 hours, where your refrigerator will shut down for about 20 minutes and your defrost heater turns on.
You do not need to clean your drain pan. You have a condenser fan that blows across the drain pan to evaporate the condensate.
You drain pan will fill during the defrost cycles. the condenser fan blow across the drain pan and will evaporate the water.
The amount of water in your drain pan will depend on conditions such as high frost in the freezer.
Mary, you had just happened up the drain pan not completely evaporating the condensate.
Sounds to me like you are in good shape.
Peter, Baltimore, MD, USA
Nov 02, 2014 | Bosch KAN60A45G Inox 510 l Fridge Freezer...
Model 22 profile reefer - water doesn't drain from the pan area below the freezer fan, causing fan fins to freeze in the accumulated water how do i resolve this issue
use hot water and a turkey baster. remove ice untill water flows and then pour more hot water thru. take small hose and blow out and then wash more hot water
Jan 18, 2010 | GE Refrigerators
I have GE Profile PDS18SBMRBS refrigerator. The drain tube keeps clogging with ice, blocking the fan that blow air into the refrigerator, hence stopping the cooling. How do I fix it permanently?
This sounds like it is not defrosting, plus the drain may be clogged not letting the water drain. The drain clog will not block the fan, but not defrosting will.
Jan 03, 2010 | GE GBS22HCR Bottom Freezer Refrigerator
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Water in freezer, runs constantly
Hi, There is a drain plugged. Look on the back of the freezer. If you can not see a drain hose, look underneath. Blow through the drain hose and clear it. If you can remove a panel near the fan motors and get to the drain there, you can clear/flush the drain out too.
I hope this helps you.
Vic
May 21, 2009 | Freezers
A/C drain pan not draining.
The drain must have one and only one trap in it. A trap is where the pipe goes up then back down so that water is kept in a section of the pipe - will stop the air from blowing thru the drain and not letting the water drain - may not sound right but it is! I've seen this many times! Drain traps are not understood at all by the HVAC industry.
May 12, 2009 | Heating & Cooling
Water collecting when using A/C
My first reaction is that it sounds like a plugged or partially plugged drain line. Clear the drain line by either blowing through it backwards (carefully) or using compressed air. In a worse case the line could be kinked or rotted. Make sure the drain can run freely into its destination. Sometimes the line will need to be disassembled to clean it.
Another cause of this can be static pressure imbalance on the fan...the drain trap should be equal to or just less than in height of the total static pressure of the fan in inches of water column so the water (condensate) is not held back by the fan pressure. Make sure your filter is clean, especially if you have pets.
Apr 20, 2009 | Coleman Heating & Cooling
1994 nissan pickup--heater not blowing hot enough air
your fan motor is shot, motor has bad brushes replace it, if u feel its still not hot, drain your rad and but a 28 oz bottle of pine sole and add water till full, run it for about 20 mins. drain, run strait water, drain, then put anti frezz in with water, 50/50 mix or mix your own. it should clean your cooling system compleatly out.. do not turn heat on while pine sole is running throw it, gives of a bad smell.
bert
Jan 28, 2009 | 1994 Nissan Pickup
Freezer fan freezes up
either drain is plugged up and water backs up and blocks fan rotation, or fan itself is bad and quitting occassionally. gently remove interior panels to access fan. is it running? if no check for 120 volts to it, usually there is a plug. got volts but no fan, fan is bad. if water backs up and is blocking fan you gently use hot water and shop vac to clean little drain hole in back bottom behind or near fan till you can blow easily through it with a short piece of hose over the hole. once clear the water can drain down toi the condensate pan by compressor and evaporate. these little fans are fairly cheap and come like a little module. be sure to observe the rotation and location of fan blade on the motor shaft . reuse the same blade unless it is loose . if replaced get same number of blades, rotation, pitch and diamater. usually they press on and off firmly with fingers.note how much blade protrudes beyond the shroud for location. not to far out or to close the the motor. good luck
Dec 07, 2008 | Refrigerators
Window unit spitting water
Check to make sure the drain holes are free from debris. The drain pan not draining causes the spitting and the fan is blowing out the water. Using a metal rod or hanger, gently clear all holes in the bottom of the unit. Prepare to get wet!
Jul 30, 2008 | Heating & Cooling
Haier HPRD12XC5 Air Conditioner Logo
141 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
