Question about Dometic Rooftop RV Air Conditioner
Ac starts kicks on and off every couple mins
The fan works great but when you turn it to ac it makes a wierd sound sound about 5 -10 seconds then blows on out and keeps dowing it the holw time its one but dotn get cold??
  • 4 Answers
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Posted on Jul 27, 2009
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
2003 Hyundai Sante fe A/C fan and rad fan not turning Fast enough while A/C is on but work OK when engine come to temp. ac starts off cold then gets warm after about 5 miles.
make sure radiator and or condensor fins are not restricted with dirt , bugs etc. poor airflow across the condensor. high side pressure could rise too high causing compressor to cycle off and on and not cool the freon properly.not sure what you mean when you say you play with the relay and it comes on. compressor or the fan? pull the relay and look at the female pins and make sure they are not spread open too wide. is the check engine lamp on? sometimes computers will disable ac for some other faults. im not sure if you mean the compressor is turning off and staying off, or just not cooling well due to fan problem. if its turning off it could be a control head problem or the pcm disabling it for another reason. or if you are manipulating the relay then compressor kicks on you may have a bad relay. hope this helps
Jul 14, 2012 | 2003 Hyundai Santa Fe
My 1996 Plymouth Neon 2.0 DOHC engine is having a overheating issue. When I run the A/C after about 15 minutes the car willstart to over heat and i have to turn it off. Once I turn it off, the guage will...
your car has two fans one for the motor the other for the ac both fans shooed
come on when the ac is on if not try hot wiring the second fan run a pos & neg
wire to it and see if it over heats it sounds like your having trouble with the fan
switch located in the fuse box under the hood
i hope this helps you
bob
Jun 17, 2011 | 1997 Plymouth Neon
AC FAN NOT KICKING ON!!
The fan could be locked up like you said but it's probably the fan capacitor. Check to see if the fan rotates then check the capacitor.
May 25, 2010 | GE AGQ14AJ Air Conditioner
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
A/c issue
Could be a couple things - one, if the fan switch for the AC condenser is not working, it'll keep the AC from kicking on, but that's usually seen by the compressor not coming on. When you activate the AC, do your RPM drop down at all? It should. If it does, the compressor is kicking on and you probably have a problem with the expansion valve, which is what flash chills the air. The car is pumping freon around but it's not cooling enough to cool the car. That's likely an expansion valve problem.
If you turn it on and the revs don't dip down momentarily, the compressor isn't coming on, and it could be the fan switch underhood or the AC relay.
Aug 29, 2008 | 1998 Volkswagen Jetta
AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Apr 16, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
304 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
