Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
No steam pressure with little to no water/steam
Hi, we have a Gaggia Syncrony Logic coffee machine which we have had for a couple of years. We haven't had any problems with it until a few days ago. The frother doesn't seem to have any pressure, it releases a tiny dribble of steam and then the red light goes on constant. The water level is fine and the machine is filled with coffee beans. I tried to descale it to see if there was a blockage somewhere, this hasn't fixed the problem. I was able to get a little water out of the steamer by turning the nob without the steamer button being pressed, though this again only let a little water out and then the red light came on. In addition to trying to descale it, I also used a pin and pipe cleaner to clean out the steam pipe. It didn't appear to be blocked. The steamer was making a funny werring noise while it was trying to dispense either water or steam. Do you have any ideas?
    President:
  • 1,618 Answers
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Posted on Jul 27, 2009
4 Suggested Answers
  • 833 Answers
SOURCE: Beans stick in hopper
The problem is that beans have particles and oil on/in them, jamming the switch which is giving you this message. Invert the unit on a hard surface covered with newspaper and give it a couple of strong taps against that surface. The junk should fall out and get you going again. Clearly, you're missing something when disassembling the unit.
Posted on May 09, 2008
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
  • 109 Answers
SOURCE: Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Posted on Feb 25, 2010
We have a Gaggia Syncrony Logic that is just over two years old. After each brew cycle, the puck is successfully ejected but water and some grounds flow out under the drip tray instead of into it....
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Dec 09, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Gaggia Syncrony logic loses water pressure. If left unused for an hour or two it only dispenses half the water it should. After this it's ok until not used for a while. Any ideas?
Yes the machine should not be left on for that long, it only takes a few minutes to heat up. It does not have an auto refill if the boiler is low on water.
If it heats up the water in the boiler for over an hour, it is safe to assume, that the water might at some point turn to steam, when you use it for the first time, it flushes out all the steam, and fills the boiler with water.
Feb 20, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
The steam wand will only dispense water, and will not steam. What can i do?
Replace the steam boiler, and or check the thermostats and the element on the steam boiler. If those are working fine then the CPU board has failed especially where the power leads to the steam, look for sign of damage on the board.
Dec 03, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony Espresso Machine does not switch on
maybe your houst from tan to steam valve is plugged,check hous and steam wand
Aug 29, 2009 | Gaggia Syncrony Espresso Machine
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
416 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
