Question about Icon MT-5800 5.8'' Widescreen Headrest LCD Monitor
There is a buzz through my lcd headrests when car engine is running. The amount of buzz & pitch is proportional with engine revs
    Scholar:
  • 173 Answers
You need a surpresser.
The problem is that there is 'feed back',
from the alternator output to the head unit.
Have fun:
Posted on Jul 26, 2009
Yamaha outboard 90/65 4stroke jet only getting 5000 rpms. New motor with 6 hours on19' flat bottom boat. Tach is flashing a engine symbol. Suggestions?
The amount of RPM's on a boat motor depend on a number of things...
1. Height if the motor in relation to the bottom of the boat. - too high and it over rev's.. Too low and it won't rev..
2. The correct size (O.D.) of the prop. Too large and you have mechanical interference or too large for the motor to spin...- ..Too small and the motor will over rev!!
3. The correct pitch of the prop. - Too large/big of pitch and the motor can't spin it..-.. too small and it will over rev the motor.
..... these are the big three...
Now, Make sure the carburetor butterfly(s) are opening exactly flat or vertical ...and not under/over opening..if this is a fuel injected motor...have the dealer check it out..
Jul 11, 2017 | Boating
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Do you have printable installation instructions for the Roadview RHM 7.0 headrest? We seem to have misplaced ours. Thank you
Headrests slots are different in many vehicles. You can take the slots out of your other car & install them into the SUV bit it is a pain to do. Most are sewed in. Take small edged knife with thin blade, cut down the side of the slot,close to metal so to cut the stiches holding it in place. Some use Glue. Then take out other slots from headrest in SUV, same way. If glued,thats good,just glue your set to use back in. If stiched,just buy Auto Uphostery Glue & use that. Will work. Good Luck,not easy task.
May 17, 2014 | Roadview RHM-7.0 Universal Replacement...
My 2008 avenger will not hold any charge in the battery. It sat still for a month where I was away and the battery flattened after which it does not seem to want to charge! I don't know if it's related but...
If yu have allowed the battery to completely discharge then the chemical reactions in it have caused the apparition of lead sulphate instead of lead oxide - this can't be decomposed so the battery has lost its capability to hold a charge. Because of that the alternator is overstressed and buzzing.
Replace the battery immediately.
Sep 29, 2010 | 2008 Dodge Avenger
Picture ok but loss of sound with high pitched buzz
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Feb 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
I cant figure this out about my headrest lcds HELP
Let me guess, you have a pioneerr dvd headunit a video amplifier and 2 headrest correct.
Now connect from V/A in at the headunit to V/A out at the video amp. Connect V/A out put from #1 headrest to #1 V/A in put at the amp. And V/A out put from #2 headrest to #2 V/A in put at the amp.
Jan 07, 2010 | Car Audio & Video
97 f-150 high pitched wine from radio, buzzing behind instruments
If the whine changes pitch with engine RPM it could be a serious problem with the alternator. Possibly the voltage regulator, or a shorted diode in the alternator causing high frequency AC to be fed into the harness.
Oct 09, 2009 | 1997 Ford F150 Regular Cab
Car Audio & Video Logo
142 people viewed this question
Top Icon Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Icon Car Audio and Video Expert? Answer questions, earn points and help others
