Question about LG Heating & Cooling
My inside fan makes a real bad noise after a wile then stops spinning
  • 614 Answers
Soungs like bad bearings in motor. Russ
Posted on Jul 26, 2009
Fan makes noise on my Dell Inspiron One 19
Usually there is a fan on the CPU heatsink and a fan in the power supply.
Open the case and turn on the computer and use a small timber stick and poke it into the CPU fan to stop it spinning and if the noise stops then this fan needs replacing.
If it is OK the the fan in the power supply is faulty. I recommend you replace the power supply because there are dangerous voltages inside this power supply.
Jul 31, 2012 | Dell Inspiron One 19 (884116044949) 185 in...
When I turn on the air conditioning it squeeks very loud. I just put in new belts. A friend said the tension is goon. How do I know if the compressor is bad
  • I would start with a can or brake clean and spray some of that on your belt as it is turning and see if there is some dirt on the belt making it squeal.
  • It can be a week tensioner. You can look with a flashlight as the belt is turning to see if you see the tension pulley is popping up and loosing tension.
  • While there with the flashlight make sure the belt is running strait.
  • A couple ways to know if the compressor is bad. First you will hear it squeal real bad or grind real bad ans you run the AC. This is an indicator of the bearings gone bad. You can also remove the belt and just give the compressor pulley a few spins. It should spin free with no hang ups or noises.
  • I would suggest that while the belt is off you spin all the pulleys to see if they spin free without any noises. Naturally the crank won't spin by hand but all the others should.
  • Also keep in mind that on rare occasions even a new belt can be bad and another new one will be needed.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 06, 2011 | Nissan Altima Cars & Trucks
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Dec 16, 2010 | HP (219426-001) Cooling Fan
I have a ratteling noise from the motor that spins the fan next to the overhead light inside the microwave. when i disconnect the motor the noise goes away. How important is this little fan?
That "little fan" is the Microwave "Stirrer" without it the magnetron will burn out real quick. Due to the microwave being reflected back. That "Fan" scrambles up the MW, and scatters it in the chamber.
Feb 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
Ice is forming in my Freezer and the roof is forming drops
Unplug it and let it defrost. wile it is defrosting pull the botum front cover off and vacum out all of the acumulated lint off the tub on the bottum. after about 2 -3 hours plug it back in and listen for the fan running on the inside if you feel air coming out of the vents then you should be OK. If no fan replace it.
Sep 11, 2009 | Kelvinator 24 in. MDB421RF Built-in...
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Fan motor in window ac/heat unit turns slow or not at all
Did you change the capacitor when you changed the fan? If you didn't you need to. And that capacitor is a dual one running the compressor and fan. So make a diagram of it what wires go where the area is real tight and some wires are the same color. You might make labels to be a little easier. Also get the same size capacitor when you change it.
Jan 16, 2009 | Whirlpool Electronic Window Air...
Cpu fan noise problem
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Sep 16, 2007 | Intel D915GAG Socket 775 Motherboard -...
GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Apr 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Heating & Cooling Logo
89 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
