Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60# ptv810 aho1
Got it for free sound works cable works picture bad. I can see red green & blue lights when I sit in front of the TV & picture is blurred How do I adjust
the projector/lights I'm pretty handy with eltronics or should I call a pro is it worth it????
  • kdt416 Apr 09, 2009
    The screen pulsates back & forth. It used to be ok after warm up. Now it does all the time.
    Problem Solver:
  • 9 Answers
Blue and green crt lenses need dis-assembled and internal cleaning and glycol coolant replaced w/ fresh stuff....tis a task for sure, if going to attempt, holla, have done a few here.
chemical reaction between the glycol and aluminum, over time will build up a fungus(non-biological) over lens(electronic glaucoma), will not happen in red one because of red light spectrum won't allow growth
Hwood
Posted on Jul 05, 2008
  • 137 Answers
Yes it is , Sounds like your Convertions is out and need to be set.
Posted on Jun 29, 2008
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
I need to know which picture tube needs to be replaced everything on my tv is mainly green
hi I would say blue and red
depending how old is your tv you should check first with screen controls located near
the right side speaker behind the front panel
there are blue red green master screen control along with focus control just turn the controls clockwise and see what happens
if the red and blue do not light up at all the tubes are not involve
good luck
Sep 29, 2010 | Mitsubishi VS-60111 60" Rear Projection...
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Big screen won't come on
There is 2 things that will cause this and most of the time SSb board is bad cost 295.00 and up or your STK ics.big black convergence ICs
Dec 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
