Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a cabrio washing machine only 21/2 yrs old and I keep
Getting the f1 light on when I go to start a load of clothes. What does that mean?
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(#$^&
Posted on Sep 21, 2010
I am getting a F1 code in my washer which causes it to stop several times during a wash cycle, what do I need to do?
Hello;
My name is Peter. I am a retired field service appliance technician.
If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
Dec 08, 2014 | Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does "F1" mean when you are attempting to wash clothes in the Whirlpool Cabrio TOP Load Washer
A fault code of "F" then "1" flashes when there is a primary control failure. You will need to replace the machine/motor control assembly. Page 14 and 16, in the manual, will help you with this.
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I get an F1 signal when I start the washer. I can get it to go away by switching what kind of load it is but it keeps coming back?
F1 means communication error, Unplug washer for 2 mins.. What might have caused this problem is a power glitch of some kind.
Jan 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
MY CABRIO SAYS SD ON THE DISPLAY
That means that the machine is sensing excessive suds. I just got the same message on my Duet today. The problem with mine, however, is that there is an issue with drainage. We emptied the drain filter and are currently trying to get it to work properly. It switched from Sd to F-21 and has repeated F-21 5 times until just now when it continued on in the drain/spin cycle to actually spin the clothes. Will keep you posted...
Aug 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error on Whirlpool cabrio
it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
