Question about Gaggia 7001 \ 7002 Electric Burr Grinder
Gaggia Syncrony Logic coffee machine with no pressure in steamer
Hi I have a Gaggia Syncrony Logic coffee machine. - (Sorry the type of machine we have wasn't listed) It is a few years old. It was working fine until a couple of days ago. Now the steamer doesn't seem to have any pressure. Water/steam comes out as a dribble and then stops completely and the red light comes on. It also seems to make a werring sound as though it is trying to dispense water. I have tried descaling, this didn't help. I even tried to unclog the tip of the steamer with a pin and pipe cleaner, but it didn't seem clogged. Any ideas?
5 Suggested Answers
SOURCE: Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Posted on Sep 17, 2007
mirran
  • 515 Answers
SOURCE: gaggia coffee
Do you prime the machine when you connect it to power?
Posted on Jul 17, 2008
EsWorld
  • 1618 Answers
SOURCE: No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Posted on Jul 27, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
Posted on Aug 28, 2009
Gaggia Syncrony Logic has no power
Check the 2 thermal cutouts located on the side of the boiler
Press to reset
Jan 02, 2013 | Gaggia Syncrony Logic 74884 Espresso...
I have a gaggia syncrony logic that has just come back from the repairers.! The coffee dregs are almost liquid whereas before they were solid patties & liquid is found in the drip tray after every...
The coffee grind could be too fine and or not enough coffee is being added to the brew chamber after the machine grinds it. You can try to adjust the amount of coffee being used for an espresso and or adjust the grind.
May 20, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Mar 10, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Need new gasket for boiler for syncrony logic
You can check with wholelattelove or servicesunlimited.
Oct 20, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia 7001 \ 7002 Electric Burr Grinder Logo
558 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
