Televison & Video Logo
Posted on Jun 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Bravia 32" KDL model TV has no standby lights and will not turn on.
Model kdl-32bx330 no standby light and will not power on. Replaced the power supply circuit board but still nothing. Wondering if board i received is defective.
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jun 19, 2017
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986494
Points
237762
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
  • pschultz584 Jun 19, 2017
    You are right on! I replaced the power supply board twice, but that did nothing. I did not think it was the circuit board with the AV jacks but it turns out that this IS the main board. Before I got your answer I took to a TV repair shop and that's what they will replace. the cost to me $130. Ouch! Main board for this TV is not in stock at shopjimmy.com right now Why would the AV CB be the main board? Wouldn't the main board be the CB where electric power connects to it? :(
1helpful
Hi I have a Sony Bravia model# KDL-32BX330 don't turn on..No light. I need to know what is wrong with it...thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Sony kdl-32ex500 error codes
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
1helpful
B+ Over Voltage Protection problem Sony Bravia KDL 32S2000
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
No Display
mainboard damaged and need to be replaced
4helpful
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
