Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Mine is doing the same thing. I talked with a local repair guy over the phone and he says that (obviously) something is malfunctioning in the TV and a sensor shuts it off to minimize the damage to other components. This would be ok if the TV were 20 years old (they used to last that long); however, mine is only 1 1/2 years old and Emerson couldn't give a damn that the TV is a piece of ****. Silly Mimi
i have a emerson lcd tv LC320EM8 32" and it is less than a year old and it just started to turn off immediatly after i turn it on can anyone help please email [email protected]
