Question about American Pro Car Audio & Video
Need schematics for a American Pro Audio VS-1407. Cannot get to turn on even by shorting the B+ to remote connection. All fuses are good.
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: AMERICAN PRO MANUAL
You need to contact these guys; http://www.americanproaudio.com/contact.html They still support the model, so thye should be able to help. Sorry doesn't appear to be available online. :)
Posted on Aug 05, 2007
  • 631 Answers
SOURCE: American Pro Amp 1406
The best solution would be to replace the fuse holder.
If the fuse holder is for the push-in fuses, you can tighten the clips. Remove the amplifier from the power source (<VERY important). Use a small flat-bladed screwdriver to push the rounded part of the clip toward the flat part of the clip (these will be visible when you look into the fuse holder).
If that dosen't work, there may be broken connections on the circuit board.
Posted on Dec 21, 2007
  • 84 Answers
SOURCE: dont have wire schematic to hook up american pro
You should go to www.the12volt.com they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to crutchfield.com and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Posted on Jun 14, 2009
  • 101 Answers
SOURCE: how much rms dose an american pro vs 1409 put out
I used to have a similar model, vs1405, and it was advertised to have 600w max. Its rms ratings were 260w bridged @ 4ohm. and 80x2 @ 4 ohm.
So I really wouldnt expect much.
I would personally suggest the HiFonics Brutus. Very nice amps for the price, and have TONS of power.
Posted on Oct 26, 2009
Theres a light on inside my amp, but the power light wont come on. ive rewired it several times and it still wont work, i really dont want to buy a new amp. what do i do?
First and foremost, check your fuse at the battery terminal. Then make sure you are getting your 12V from your remote turn on, and lastly make sure all of the connections are properly terminated.
Sep 19, 2010 | American Pro VS1404 Car Audio Amplifier
Need a wiring diagram for a american pro 1406
Very simple :
12V+ = Red 8 Gauge Wire to positive battery terminal with a 30 Amp fuse
Ground = Black 8 Gauge wire to non painted surface on chassis of car.
Remote Turn on = Blue / white thin wire from radio's blue/white , this will turn on your amp.
A set of RCA cables which are self explanatory. Out to In or In to Out
Radio to Amp under carpet to back of vehicle along with your blue wire.
Then you have your speaker wires, you hook these up to your subwoofers.
Hope this helps, good luck.
Lex..
May 21, 2010 | American Pro VS1406 Car Audio Amplifier
It wont get power
Check the primary fuse on the positive amp wire usually located near the + battery post. Also check any onboard fuses. If these check OK, make sure the remote lead has 12V+ on it when the head unit is turned on. If these all check out, the amp is most likely defective.
May 16, 2010 | American Pro VS1405 Car Audio Amplifier
LED LIGHTS DONT TURN ON
3 Options.
Check your powerwire, and make sure you fuse in your power wire is good and that your getting power.
Make sure you have a good ground. A bad ground will not allow your amp to turn on
Your remote wire that runs from you stereo. Make sure it's connected from you H/U to your amp. If you forget your remote wire(Blue), your amp will not turn on.
Aug 31, 2009 | American Audio VLP300 Power Amplifier Car...
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
Not sound
The only thing I can think is the +/- on the speakers are backward or no signal from remote wire....
The green power light is on I presume?
Mar 05, 2009 | American Pro VS1404 Car Audio Amplifier
Amp Turns on Fine, but no Sound
have you checked the levels on the ohms? adjust them higher if need be contact me on yahoo msgr if you need more assistance
jcbproducts-always forward
ym-jcbproducts
Nov 14, 2008 | American Pro VS-2043 Car Audio Amplifier
Car audio
depends on what sort of amp you have iv got american pro 1407
Jun 01, 2008 | Car Audio & Video
How to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
You blew the output transistors. They all need to be replaced. Check this for more info: http://www.techlore.com/article/14696/
Aug 14, 2006 | American Pro VS-2043 Car Audio Amplifier
Car Audio & Video Logo
271 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
