Question about Dell Inspiron B130 Notebook
Will not detect harddrive
My B130 laptop is hard to get into the startup and boot menus. It absolutely will not go into either setup with a HD installed. Without a HD it will even start loading windows XP OS until it says no storage device present. I ran the diagnostic disc and everything passes the tests! What would the problem be that it will not detect the HD? I have tried other HD's that are good.
  • 181 Answers
You need to go into the bios (f2) at boot. Configure the drive selections according to the drive you have; sata, ide, etc. It's probly just a wrong setting.
Good luck
Posted on Nov 22, 2007
Acer 5100-5022 laptop won't properly recognize any harddrive
Sounds like the battery for BIOS is bad and the system is loosing CMOS data or the CMOS circuitry is bad.
Aug 20, 2012 | Computers & Internet
Will not boot up
Even when it is being charged? And is the actual computer not turning on or is it turning on and the screen is showing no picture. two different problems.
Jun 30, 2011 | ASUS Eee 4G Notebook
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Why is it when i go to start my computer it doesnt wanna load windows, it says disk boot failure, insert system disk and press enter. My computer was working fine right before. can someone please tell me...
Hi, the computer is not detecting the hard drive or the hard drive is corrupt. At startup you are likely to hear a knocking sound if the hard drive is physically damaged. You can go to bios setup at startup ( could be F1 or Esc). Once there it should indicate if there is a harddrive or not. If it indicates none there the harddrive might have crashed and will need repalcing. I hope this helps.
Aug 12, 2010 | HP Pavilion a706n PC Desktop
Vaio operating system not found.
first check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
May 06, 2010 | Sony VAIO VGC-LV110N PC Notebook
My computer t-40 laptop starts to boot but then shows pxe-e61 media cable disconected pxe-mof intel boot agent,I bought this laptop used ,I was told that it was tring to boot from a net instead of...
Hi there, please try this trobuleshooting steps. after you push the power button quickly tap the F12 key until you reached too boot options menu. once you are already at the menu, select you Hard drive usually harddrive represent as model e.g WDC **** it means western digital. once you slected the harddrive your computer should boot now to your Harddrive. if else fails, waht you need now is to check if you cmputer was able to detect you harddrive. restart the computer then this time keep tapping the F1 key to enter the utility setup. once inside the setup check your system information under internal HDD if motherboard can detect your harddrive. if yes, then all you need to do there is to use the recovery cd that came with the system then boot your computer from the cd rom then install you windows. If not, then you have to contct your manufacturer. that could be a defective harddrive. please let me know if you need more help.
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
No Operating System found
You can open the harddrive cover to check.
Most likely the drive is broken and needs to be replaced.
Its going to cost you, but take the laptop to a repair service / shop / center.
Thats if you dont have warranty.
You can try reconnecting the harddrive.
But If it already was well connected. Its most likely broken.
Mar 09, 2008 | Toshiba Satellite A105 Notebook
Blue Screen with error messages
Startup your laptop keep clicking f8 until you see option like star in safe mode just click on "LAST KNOWN GOOD CONFIGURATION(your most recent settings that worked)"
Simple as that ;-).
Dec 29, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
147 people viewed this question
Alun Cox
