Question about Canon PIXMA MP160 All-In-One InkJet Printer
How do i do a head alignment? - Canon PIXMA MP160 All-In-One InkJet Printer
  • James Ely May 11, 2010
    This link will show you exactly how to do it.http://www.usa.canon.com/consumer/contro... Open up your printer's software from your Programs Menu. Go to START/SETTINGS/PRINTERS and FAXES. 2. Select the maintenance tab, 3. Click the 'Print Head Alignment' button.
    4. Click 'OK'. The pattern will be printed.
    5. After the pattern is printed, click 'Yes'.
    Align the Print Head
    1. Look at the printout. From the patterns, select the most even and least irregular patterns.
    2. Enter the numbers.
    3. Click 'OK'.
    * If it is difficult to determine the best pattern on Column E, then pick a setting that has the least noticeable white stripes
    There you should find a printer maintenance link to print test pages, clean the nozzles, and do head alignment. If not, type your question in the search window. This link will show you exactly how to do it Thanks for letting me help you. Repost any questions and I will be sent an email indicating a comment on my solution and I can further assist you. Good luck. Please rate me if you found this helpful :) You can also go to Canon's web site, enter your model number and get answers there specific for your printer.
  • 28 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-24
Posted on Sep 04, 2009
    Genius:
  • 1,043 Answers
Under your printer properties there should be a tab called Maintenance. There is where you will find the Print Head Alignment utility, as well as the Head Cleaning and a number of other useful utilities.
Posted on Jul 26, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
On your desktop -
Start button, printers and faxes.
Right click on the printer in the window that pops open and select 'properties'.
The window that opens will have several tabs, select the 'maintenance' tab and then 'print head alignment'.
The application will guide you from there.
Says problem with alignment. Remove tape from cartridge or check troubleshooting. There is no tape on cartridge so what should I do?
It may mean the print head alignment rather than the cartridge
Check properties on printer in control panel and see if there is a head alignment option.
If there is it will print out an alignment page that you can compare to see if alignment is out on the print head.
Try also Google search engine
printer model and print head alignment
Dec 05, 2016 | Office Equipment & Supplies
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
What is E7 on the canon mp160, and not working anyway..
When the head alignment sheet was not filled in properly Printer show E7.
  • Confirm circles on head alignment sheet are filled in properly MP160
Head Alignment Sheet The head alignment sheet was not filled in properly.Confirm the circles were filled in as follows:
Good example:
Bad examples:
If more than one circle is filled in, reprint the Head Alignment Sheet.
  1. Ensure that the printer is powered on and open the paper output tray. (Confirm that the paper thickness lever is set to the left.)
  2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder (or ASF).
  3. Press the <Maintenance> button several times until [P] is displayed in the LED.
  4. Press the <Black> or <Color> button. The machine prints the head alignment sheet.
  5. From each group, select the pattern which has the least visible streak.
    Example of the pattern with the least visible vertical streak
    Example of the pattern with the most visible vertical streak
  6. Pencil in the circles on the left side of the selected pattern, using a dark pencil.
    < 1 > Good example
    < 2 > Bad example: Checkmark
    < 3 > Bad example: Line only
    < 4 > Bad example: Not dark enough
  7. Open the document cover and load the head alignment sheet on the platen glass.
    Note: - Place the printed side down.- Align the sheet with the alignment mark (shown by the arrow) on the lower right corner of the platen glass.
    05sj00115_06.gif Alignment Mark
  8. Close the document cover gently.
  9. Confirm that U is displayed in the LED.
    If U is not displayed, press the <Maintenance> button several times until [U] is displayed in the LED.
  10. Press the Black or Color button.
  11. The machine scans the head alignment sheet and aligns the print head automatically.
Feb 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer head alignment is not aligned from A to F.
go to "printer and faxes",then right click on the printer ip 1800 and go to the 'properties'.....then click on "clean head".......
do it many times until the head alignment is ok...
Jan 07, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
389 people viewed this question
old marine
old marine
