Try using an AC power supply rather than a battery. You should also try a reset. This will take it back to the factory settings to do so, - Press Utility while powering up let go then press Parameter up. If all this fails, it's time for the repair shop.
Try a factory reset. This is the procedure 1. Press and hold the Store button while powering up the RP90. 2. When the display prompts you with FR, release the Store button. 3. Press and hold the Store button for 3 seconds until RS appears in the display and release. The Factory Reset procedure takes approximately 10 seconds. 4. Once the factory reset has finished you will need to calibrate the Expression Pedal.
