Question about Electrical Supplies
I need a fuse block (it's the part that holds the fuse and is inserted into the fuse box). This fuse block holds 2-50 amp fuses and is mounted to the electrical pole outside of my house. Then the electricity runs into the house through a breaker box. These were used 30 to 40 years ago when power poles were put up for mobile homes.
  • 5,660 Answers
What you are wanting is an Outdoor Disconnect Switch- 100 AMP, but this panel is an example of what to look for,
http://electrical.hardwarestore.com/14-51-breaker-box-100-amp/100-amp-mobile-homeline-panels--642643.aspx
Posted on Jul 26, 2009
  • joecoolvette
    joecoolvette Jul 26, 2009
    Feel free to rate my solution.
What does d/l stand for in fuse box ford ranger 30 amp inserted
Possibly for power door locks might have a short
Aug 17, 2012 | Ford Cars & Trucks
How do i drop the fuse box to replace the bcm
Unscrew the two bottom plastic covers. With a 1/4 ratchet and 5/16 socket remove three black screws holding the fuse panel to it's mounting bracket. one screw is on the left side and two screws are on the right side all facing toward the driver. Unplug the two large wire connectors from the bottom of the BCM. You still cannot remopve the the fuse block but you don't need to. Next remove two screws on the right side of the fuse block with your small ratchet. You will need to have about a eight inch extension to remove the one screw that is located on the top of the left side of the fuse box. I used a mirrow to guide the socket straight up along side the fuse box and was able to remove the screw. It really was not a hard thing to do. When the three screws are removed, the BCM will slide down and seperate from the fuse box. Reverese the procedure the reinstall. Good Luck
Jan 12, 2012 | 1996 Plymouth Voyager
Can someone tell me where to find the fuse box on a 1985 honda shadow 500.> Thanks. email me > dan.kozlauskos@att.net
Your fuse box is located on the handle bars under the black "HONDA" plate. You will break it off if you just grab it and pull. It is held on by two screws that face the fuel tank.If you have a very short phillips insert from a screw driver and a small box end wrench you can some times safely take the screws out with out removing the fuel tank. That technique works on the CX650 hopefully it will work on the VT500. Otherwise you will have to take off the seat and the tank. This will get much easier access to the fuse block cover mounting screws. The guy that designed that pretty piece of plastic did not do any of the owners a favor. Be careful not to break it for you may not be able to get a replacement from Honda.
Mar 25, 2011 | 1985 Honda VT 500 C Shadow
I cannot remove the 100 Amp fuse to replace it. How do you get it out of the fuse box?
The fuse link is bolted in from the two side in the fusebox.you have to un bolt the whole fusebox so you can raise it and if you look at the sides there are two side panels that can be moved down so you can get a socket or spanner on the two bolts apprx 10mm. undo them and raise the fuse out and put the new one in and tighten up the bolts again.
Dec 13, 2010 | 1993 Toyota Corolla
Were do i locate my feus box
There are two fuse boxes
1. Passenger compartment
The Passenger compartment fuse block access door
is on the driver's side edge
of the instrument panel. Pull
off the cover to access the
fuse block.
You can remove fuses with
a fuse extractor. The fuse
extractor is mounted to the
2.Underhood Fuse and Relay center
The underhood fusehelay center is located in the rear of
the engine compartment near the brake fluid reservoir.
Move the retainer clips for the cover to access the
fuse block.
You can remove fuses with a fuse extractor. The fuse
extractor is mounted to the interior fuse block. To
remove fuses if you don't have a fuseex tractor, hold the
end of the fuse between your thumb and index finger
and pull straight out.
Nov 11, 2010 | 1997 Chevrolet Suburban
My 2002 galant fuse box has melted where the ac fuse goes can it be fixed without replacing the fuse box?
Hello stanford8
A new or used fuse block is the recommended way to go. But in a
pinch, remove the fuse box mounting screws and pull it back to make
sure no other wires got melted or damaged. Cut the power out a/c wire
from the box. I should have said this first, pick up an inline fuse+holder
with the correct amp rating. connect one end to the 12v pwr in connection to the fuse block and the other end to the a/c power out wire
This will bypass the fuse block for the a/c only. The fuse holders are
available at any parts store. Also it would be wise to locate and repair
the cause of the meltdown first, if you havn't already done so.
Hope this helps.
Jul 16, 2010 | 2002 Mitsubishi Galant
I need to know if i need a new headlight switch or if i need a fuse replaced, but i need a diagram of the fuse panel.
The fuse block on all models is located under the left hand side of the instrument panel. All flashers are mounted on the fuse block. Each fuse is marked on the fuse block as to which circuit it is protecting. Some early models also use an in-line 30 amp, fuse for the air conditioning hi-blower, located at the cowl relay and an in-line 10 amp, fuse for power antennas.
Check this diagrams...
Fig. 19: Chassis wiring - 1981-83 Cutlass
Fig. 20: Chassis wiring - 1981-83 Cutlass continued
Hope this help.
Mar 11, 2010 | 1983 Oldsmobile Cutlass Supreme
How to get to underdash fuses of a toyota matrix
The 15 amp dome fuse is in the fuse box under the hood and the 15 amp CIG fuse is in the lower finish panel up under the dash on the drivers side. These are needed for the radio. The above fuses plus the 15 amp Gauge fuse in the box with the dome fuse under the hood are needed for the clock.
If the clock is the only defective module, I have removal instructions and a repair service. Check out www.autoclockrepair.com
May 08, 2009 | 2005 Toyota Matrix
Removing the 8o amp main fuse from 1986 Toyota pickup
yes, you must remove the top panel on the fuse block the 80 amp fuse is bolted to the the fuse panel, hope this helps if not get back to me as i strive to be the best please rate my fix Thanks Ray
Apr 29, 2009 | 1986 Toyota Pickup 4WD
Electrical Supplies Logo
163 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
