Question about HP Office Equipment & Supplies
Photos have thick even vertical lines of faded colour running through them
    Problem Solver:
  • 17 Answers
This might be caused by the quality of the media you are using. Are you using the correct paper for your printer? Try using paper specifically formulated for your printer - for example, for an HP printer you need to use HP-branded paper for the best results.
Posted on Jul 27, 2009
Lines run vertically through the screen but only onlive view
you mini lcd screen is having troubles.. it will soon out of use..contact a technician as this is a mechanical problem
Oct 07, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
MY PROBLEM IS MY 230 PRINTER VERTICAL PRINT IS NOT
I have problem while printing colour photos and I would like to know how to print back to back i.e. even and odd pages
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Vertical line appearing while phone is in shooting mode
Try turning it off for 2- 3 mins, take off it's battery, put it back in and turn it on.
If still not, you need to bring ot over to the store where you purchased it for assistance!
Jun 05, 2009 | Sony Ericsson K550i Cellular Phone
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Vertical lines and distorted colour on display screen
Just as I got on line to this site I saw your problem being typed in and it's the exact same issue I am having with my Finepix 5000. I've owned it for all of 4 plus years with no problems and really decent photos. I'm getting a blurred image with green/magenta colors when I look through the viewfinder. When I take a photo, it shows the same. It wasn't dropped or even barely touched between the last good photo taken and this. Attached is an example of above description. I would appreciate any advise. See below.7ccd05c.jpg
Feb 16, 2009 | Samsung NV10 Digital Camera
Printer Problem - Konica Minolta 7450
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Line across my laptop screen
The graphics part of the laptop is going out. Recommend just replacing the laptop, it would be cheaper.
Jun 10, 2017 | Computers & Internet
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
