Question about Janome D'cor Excel 5018
L am doing zigzag stich and the pattern is appearing on the reverse side of material, not topside.
  • howell8 Jul 26, 2009
    I have already checked the tension!
    President:
  • 1,734 Answers
Try adjusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
Posted on Jul 26, 2009
  • 285 Answers
The problem is likely to be an incorrect tension adjustment. Try adjusting tension either way and see if it improves.
  • Dean
    Dean Jul 26, 2009
    Its almost impossible for it to be on the backside? You dont have your colors mixed on the feed roll and bobbin?
I have a Kenmore 385 17724490. When I use the zigzag for my quilt it works great for a short time then it goes straight. What do I need to do for it to keep the sew zigzag ?
try this take machine oil and oil eerier where the buttons that
changes for different stiches, then set the machine for straight
stich take a piece of fabric and sew on it for a 1 minute do the same for every different stich do this for halve hour, by doing this
your getting the different stiches in order and gear to synchronize
together.
hope this helps.
Feb 08, 2018 | Kenmore Sewing Machines
Just I need help to know how to stich stretchable material like licra or similar maerial...
Asha Hello,
ok I have looked at a photo of your machine, it looks like it may have the stretch stitch. It is designated on the sewing machine per the instructions in the manual. The stitch is similar to a zigzag with a flat side to it. Check with Youtube for "stretch stitches lycra spandex". that may get you a video to watch.
Cheers,
Embroidery Services
San Diego, CA
Jul 28, 2016 | Singer Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Sep 28, 2014 | Bernina Sewing Machines
Janome 6125qc
Although you have selected a zigzag have you also set the stitch width and length manually as required? Some stitch types have restrictions on the width you can set so it's important to know which these are.If you don't have the instruction book it is available as a free download from Janome. Go to www.janome.com, click on the Machines tab then choose 'retired' and scroll down until you find the 6125QC - the link to the user guide is in the top right corner of the specifications tab.
Nov 02, 2013 | Sewing Machines
Stitches not forming correctly
the material may not be thick enough to make a correct stich, you might try interfacing with the single layer of material & see if that helps
Mar 05, 2012 | Kenmore Sewing Machines
Singer curvy 8778 the needle is making the motions to stitch evenly, but the stiches to the left are missing, not the thread mind you. So a zigzag stich appears straight. I have done all the...
Call Singer at 1-800-4singer, sounds like a buttonhole lever problem. Is it like that on all styles of buttonholes? Check that out before you call them, and make sure that you pull the lever all the way down.
Apr 16, 2011 | Singer Curvy 8770 Electronic Sewing...
My sewing machine juki is not running. The stiches is too tiny and unless you pull the material it won't run . Do you havethe idea why and how can I solve it?I was using it before and all of a suddent it...
I would go to there web site and Down load the manual to the model you have. You should find what you need to know about setting patterns in it.
Feb 22, 2011 | Juki Sewing Machines
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Aug 19, 2009 | Singer Electronic Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
