Question about Pioneer TS-SWX310 Car Subwoofer
Ive bought 2 of them . after 1 week they both sound distorted. only running a pioneer 760 amp to itthere is nothing wrong with the wiring
  • 5,603 Answers
If they were OK at first, you maybe put too much power into them and fried the voice coil. If so, it is fatal and they would need to be re-coned.
Posted on Jul 26, 2009
It cuts out when slowing down
Free scans are a waste of time
Your here & nothing has even been diagnosed
If the scan was done at a repair shop, you leave it
there, have it resolved, unless you have diagnostic
manuals & decades of experience, to do you own
work at home
Sep 11, 2012 | Cars & Trucks
Whats the best kind of amp to use with two of these in a box
Walmart sells a 760 watt 2 ch amp.....It works well with these type of subs. Or any amp rated @ 150 watts per channel RMS. Start with the low pass filter on and with it hooked up and playing raise amp level until distortion can be heard through subs...then back off a bit...Your level is now set.
Sep 17, 2010 | Pioneer TS-W1201C Car Speaker
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
I have a pioneer 760 2 channel amp bridged to a kicker comp vr woofer. Amp has 8 gauge power and ground 18 gauge speaker wire run to woofer wooofer has 4 inputs two - two + . mine is run amp + to woofer +...
Ok, without knowing if you have the 2 or 4 Ohm Dual Voice Coil (DVC) version of the subwoofer, I'm going to assume you have the dual 4 Ohm version. The reason why is because, assuming you have the Pioneer GM-5300T amp, that amp does not support an 8 Ohm load. If you wire it in parallel, that would give you a 2 Ohm load. Parallel will be solid red connected to red/white dot, then to amp +, and solid black to black/white dot to amp -. Without knowing more specifics on the amp, that should fix the problem. Let me know what you get.
Apr 30, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
they want you to "level match" the amps head units voltage from the rcas .this is best done with the radio at 3/4 volume , turning the amps gain dial till music distorts then backing off till it sound s clear .if theres other units in the signal chain (eq,x overs, ) see if they too have gain /volume controls . it goes down the line if thats the case . .
Nov 23, 2009 | Pioneer Car Audio & Video
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Choppy and distorted sound during gameplay with an optical cable
Check your pioneer unit settings, the ps3 settings are correct, and make sure you unplugged the audio cables. It sounds like a bad signal somewhere, which would cause the speakers to clip and distort. Make sure all of your surround sound speakers have a good connection if they have single wire runs to them and not a audio plug in them and there are not broken wires, or wires touching.
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Distorted sound coming out of SW channel only
try turnind down the sub from the amp itself it might be putting out more volts than the subs input can handle check your standing wave feature to make sure the trim is not up too high
Jan 13, 2008 | Pioneer SX-315
Pioneer TS-SWX310 Car Subwoofer Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
