Question about Coleman Powermate Powermate 5000W Generator
I HAVE AN OLDER POWERMATE COLEMAN 5KW. NO ELECTRIC OUTPUT
I HAVE AN OLDER POWERMATE COLEMAN 5KW. WAS NOT PRODUCING ANY ELECT. CKD THE ROTOR WAS OPEN, ORDERED AND INSTALLED NEW ONE. CKS BRUSHES, DIODES, AND CAPACITOR GOOD. STARTED UNIT AND MY VOLTMETER READS 135V. AT RECEP. BUT WHEN I PLUG IN A LOAD NOTHING HAPPENS. ANY IDEAS. DO I NEE3D TO FLASH AND HOW DO YOU DO THIS? WHAT SHOULD I READ ON VOLTMETER AT THE BRUSHES WITH MOTOR RUNNING?
  • 2 more comments
  • larrymule454 Aug 16, 2009
    THE MODEL IS A PM0545212.02 ALSO, THE VOLTAGE DOES NOT DROP WHEN I PLUG IN A LOAD, JUST WONT OPERATE LOAD. ALSO TO I NEED TO FLASH THE NEW ROTOR. THE STATOR HAS 7 LEADS, 2 WHITE, 2 BLACK, 2 RED, ONE BLUE, HOW DO I CHECK THE WINDINGS IF THIS IS THE PROBLEM. SOMEONE ADDED NOTE OF 75 VOLTS DC. IS THIS THE VOLTAGE I SHOULD READ ACROSS THE BRUSH TERMINALS?
  • larrymule454 Aug 17, 2009
    the model is a pm0545212.02 it is 5 kw 10hp. i check the voltage at the plugs from neutral to line with volt meter check one plug while load is plugged in. check line to ground and no reading. tried various loads, lights and tools
    pm0545212.02
  • Bobcatflusa May 11, 2010
    Giving the model number would be more help.
    President:
  • 1,714 Answers
Around 75 volts DC
Posted on Aug 05, 2009
Testimonial: "SORRY FOR THE DELAY, YES AND THE GENERATOR IS NOW OPERATING NORMALLY. THANK YOU SO MUCH FOR YOUR HELP AND EXPERTISE. LARRY KINCAID"
  • 3 more comments
  • Craig Butler
    Craig Butler Aug 05, 2009
    This is curious, you say you have 135 volts. That's what we call 'no load voltage'. What is happening is as soon as you put load on it it drops to zero. What that is, is a bad connection dropping the voltage down. Check all the connections on the recepticle and on in to the stator output. You will see it.
  • Craig Butler
    Craig Butler Aug 17, 2009
    Please tell me how you are testing the voltage? With a load plugged in, do you have 135 volts in the plugs? Are you checking to ground, or right between the hot and neutral, in the plug? I can tell you how to flash if we need to, give me the model number if yo know it.
    If you have 135 volts between the hot and neutral, in the plugs, that should run it. Have you tried some other power tool or just the one?
  • Craig Butler
    Craig Butler Aug 18, 2009
    I will send flash instructions, to flash field
  • Craig Butler
    To flash field:
    Using a 6 or 12 volt battery, connect + lead from battery to top right brush. Negative to other brush. With gen running touch leads to brushes for 2-3 seconds. May need two or three attempts. Recheck voltage output. If still no output, may need to check capacitor 9 (behind end cover) for open or shorted condition.
  • Craig Butler
    Craig Butler Aug 19, 2009
    Did you flash the field? I did not hear back...??
Have a coleman powermate 6750 generator that has quit producing power.
If the engine is running with the alternator not outputting then you must check with the LOAD TRIP switch.
if not remove the load and check if there is output. If not there is fault in tha alternator which might need some consensus.
Nov 05, 2011 | Coleman Powermate Powermate 5000W...
No output coleman powermate pm401211
Check the capacitor first,check rotor diodes, rotor and stator for shorts, and brushes
Oct 27, 2011 | Coleman Powermate Powermate 5000W...
How to flash or remagnitize Coleman Powermate 6875 or Husky 40500
Field Flashing of Portable Generators This tip comes from the Briggs & Stratton Customer Education Department. As an alternative to flashing a rotor winding with a battery applied to the brushes, an electric drill may be used. Follow these steps to flash the generator:
  • Plug the electric drill into the generator receptacle. (Cordless drills do not work)
  • If the drill is reversible, move the direction switch to the forward position.
  • Start the generator
  • While depressing the trigger on the drill, spin the drill chuck in reverse direction. This will excite the field and the generator will now produce electricity. If spinning the chuck one direction does not work, try spinning the chuck in the other direction as you may have the reverse switch positioned backwards.
Use caution not to get your hand or other materials caught in the chuck. As soon as the field is excited, the generator will produce power and the drill will turn on.
The reason this works is because the electric motor in the drill will act as a small generator when spun backwards. The magnets in the drill's motor induce a voltage into the motor windings, which is fed back through the trigger, cord and into the generators receptacle. From there it goes into the power winding of the stator. The voltage going through the power winding creates a magnetic field, which is intensified due to the iron core of the stator laminations. The rotor intersects this magnetic field as it is spun past the power winding, thus inducing a voltage in the rotor winding. Once current flow is present in the rotor winding the rotor has been flashed.
If flashing the field does not make the generator work, you may have additional problems, besides a lack of magnetism in the rotor. Further testing will be needed. Hopefully, this will give a simple way to field flash your generator if needed - Bruce Perrault
Apr 27, 2010 | Coleman Powermate Powermate 5000W...
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
May 30, 2009 | Coleman Powermate Portable Generator...
Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
I have a coleman 5000 that runs fine but it stops producing power after it runs for a couple of minutes.
Same answer as the last time you asked, likely a flying open. If the rotor test proves that your rotor isn't opening up, test the capacitor on brushless models or the voltage regulator board on brush generators.
Regards,
Carl
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
Generator will not produce electric power
Check the air cleaner to make sure that it isn't clogged with oil. If you find any significant amount of oil you may also need to clean the carb. Also check the spark plugs for fouling. Once you're convinced that the engine has no service related issues, check the governed throttle setting. To do this find the spring that pulls on the governor arm and look for either a tab to bend up or a threaded rod to tighten at the end of the spring not connected to the governor arm.
Regards,
Carl
Feb 10, 2009 | Coleman Powermate Powermate 5000W...
Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
Sep 04, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
1,184 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
