Question about Instant Cameras
MB-16 Battery Grip
I have purchased an MB-16 battery grip for my Nikon N80 camera. The instructions are not in English. Could you tell how to remove battery door from N80 camera? Thank you
4 Suggested Answers
  • 667 Answers
SOURCE: F100 rubber grip peeling
double stick tape is what I would use. mosts glues are to thick and not compatible with the body materials
Posted on Jan 29, 2008
  • 121 Answers
SOURCE: Battery grip for Canon Eos 400D DSLR Camera
Please see this page, on Safari Books Online - an excerpt from Canon® EOS Digital Rebel XTi/400D Guide to Digital SLR Photography which describes the steps in detail.
Posted on Jan 11, 2009
  • 1606 Answers
SOURCE: Nikon N80 takes one shot, then needs abt 10 sec cooldown
If your batteries are fresh ( have seen flat new ones older stock) and are using alkalines then I would think you have a connector problem. Can you check and clean the connectiosn inside the grip and on the camera body. I've also seen dirty lens contacts and even a sticky shutter cause this. It's usually not serious just rather annoyng until you find it.
Posted on Apr 22, 2010
  • 10865 Answers
SOURCE: hi, my batteries in the
Hello qpray... I suspect that the voltage in those new lithium batteries is too high for your camera. Check your manual and see what batteries are recommended. I think once you get different batteries your problem will be solved.
Thanks for choosing Fixya!
Posted on Jan 25, 2011
0 characters
1 Points
Can I get user manual for Nikon MB-40 multi-power battery pack for F6 body?
I think the extent of the instructions is on the Nikon USA web site. Here it is
"The Nikon MB-40 Multi-Power Battery Pack accommodates eight AA (alkaline, lithium, or Ni-MH) batteries, or the Nikon EN-EL4 Rechargeable Li-ion Battery. The MS-40 Battery Holder comes with the MB-40. With the MB-40 attached, film can be advanced as fast as 8 fps.
When using the EN-EL4 battery, the Battery-Chamber Cover BL-3 must be used.
The MB-40 is also a vertical grip, and features a vertical grip shutter release, an AF start button, and Multi-selector and Command Dials for more comfortable and responsive shooting."
Oct 15, 2014 | Nikon Used MB-40 Multi-Power Battery Pack...
I have not used this camera in years and assume that film battery is dead - green light flashes and also wondering if tab is not on the film - how do I get out. Is there a place other than film to put...
Polaroid 600 film cameras only have a single battery, built into the film packs. To remove the film pack, open the door on the door and grip the sides of the pack and slide it out.
Jul 06, 2011 | Polaroid One600 Pro Instant Camera
I recently bought a nikon f2. After I bought a battery (single 3 volt as recommended by the person at batteries plus) I opened the battery compartment, with the positive pole pointing out, closed the...
The Nikon F2 for me is the best mechanical film camera ever produced. The only electrical or battery- dependent part is its metering. Meaning to say, even without batteries, the F2 should work and take pictures on all shutter speeds. Most probably, the F2 that you bought has a non-working photomic meter finder due to a defective ring resistor, a part that is usually the first thing that would fail on this camera. What, then, are your options? One, have the meter fixed by a competent manual camera technician. Two, buy a working Photomic finder and replace what you have. Three, buy or use a handheld meter. Four (the least expensive), use the sunny 16 rule. As added reference, here's a link that might help enlighten you more about how the F2 metering works:
Mar 07, 2011 | Nikon Instant Cameras
I was given a nikon nikkormat el camera and i can't find a battery compartment
The battery compartment is inside the mirror box, on the lower side. To change the battery, remove the lens, lock up the mirror, then push the lid to the left and lift it up.
You can download a copy of the manual from
Feb 17, 2011 | Nikon Instant Cameras
Removing Nikon FM2N top plate
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Jul 08, 2010 | Nikon Instant Cameras
Where is the battery compartment on konica z-up80camera
Under the strap at the grip there are two screws - i assume this is a Z-Up80RC ? Takes a 2CR5 Battery. The non RC model has 'standard' b attery cap at the base, so i assume yours is a RC ?
Jun 01, 2010 | Instant Cameras
Mirror locked up on Nikon F75
Try pressing and releasing the shutter button. If that doesn't do anything, then turn the camera off and on and press and release the shutter button. If that still doesn't do anything, then turn the camera off, remove and reinsert the batteries (or a fresh set, if readily available), turn the camera on, and press and release the shutter button.
I ran across a Nikon N80 last week which hadn't been used for many moons. I tried the shutter and the mirror promptly locked up. It took about half a dozen tries, but the mirror eventually shook loose or whatever, and the camera now works perfectly.
If the above procedure doesn't do it, then you may have to take it in to a good camera shop for a CLA (clean-lubricate-adjust), the camera equivalent of an automobile tune-up.
Feb 05, 2010 | Nikon Instant Cameras
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
Jul 26, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Old hasselblad film camera
Undo the retaining nut on the bottom and slide the camera back to remove the grip assembly. The plate on the bottom of the camera is notched to mate with the plate on the grip
Feb 05, 2008 | Instant Cameras
My camera is showing an error code. How do I trouble shoot
normally this problem comes when the apparture selector ring is not sat to highest appartutr. i.e. f22 or whatever highest apparture available with the lense. just lock it there .
Nov 11, 2006 | Nikon N80 with 28-100 lens 35mm Film...
Open Questions:
Instant Cameras Logo
124 people viewed this question
Top Instant Cameras Experts
Steven Wander
Steven Wander
Are you an Instant Camera Expert? Answer questions, earn points and help others
