Question about Creative Labs EMU 0202 Sound Card
Emu E6400 Ultra: problems that have just started: 'Fatal Error' messages on screen; text is unreadable but it is not an LCD issue; can not re-install OS, floppy drive just hangs; can not save work via SCSI, 'Bank name' just hangs after pressing OK. PLEASE HELP :-(
When i Start the game.Then it comes an error.SAYS(Fatal error: Couldn't flip Directx message: Unknown error)
The problem with your game is that the DirectX component compatible with the game is not installed properly or there are some files missing in the DirectX directory.Try re-installing the DirectX.
Thank You
Dec 26, 2012 | Project IGI IM GOING IN
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | OKI C5200n Laser Printer
I was using txt2day.com/a website that allowsyou to send free text messages to cell phones and I ot a notice via my email saying there was a"fatal error" fom MAILER-DAEMON and that the recipient...
Could br a DNS Error of the name of the email i.e.(1234567890@vzpix.net) has changed and the problem with www.txt2day.com they sometimes don't keep up with those changes.
Mar 31, 2011 | txt2day.com
My phone does not have any problems, I was just wondering if you could tell me how to remove the envelope from the screen, Thank you
This means you have a text message, look for something that says "messages" and go in and read them all. After you read them or delete them the envelope will go away, if you have problems ask someone to help you find your text messages in your phone.
Sep 02, 2010 | Lands Phones
I am getting this error in my laptop when start windows. ''Fatal Error Driver Start EPHD Return False.''
HI,,
ITS PROBLEM WITH URS RAM ,,
IF U HAVE 2 NOS RAM,FIRST REMOVE ONE RAM AND ON THE LAPTOP,IF ITS RUN GOOD WITHOUT GIVING ERROR THAT MEANS OTHER RAM HAS PROBLEM ,,,
TNKS
RABBANEES
Nov 12, 2009 | Dell Latitude E6400 Notebook
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Team H20 CLDEX not working
Usually this error occurs when Syncrosoft-Emu (H2O) is installed twice. Go to start menu Run type msconfig and go to start up tab. uncheck or disable cledx.exe , then okay
Reboot the machine.
When you start cubase you will have to start true emu manually to startup cubase.
Char S.
May 26, 2009 | Toshiba Satellite U300-ST3091 Notebook
FATAL ERROR
Hey,
It seems this is not an issue with the computer.
you just need to download and install the Direct X on your computer.
you can download it from the weblink below. Just click on "Click Here to Download"
http://www.brothersoft.com/directx-download-225647.html
hope helps..
Apr 02, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Open Questions:
Creative Labs EMU 0202 Sound Card Logo
213 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
