Did you check for voltage and ground at the lighter socket wiring. In the diagram, orange wire is voltage, black wire is ground. Got to have both voltage and ground.
Did you use a test light and check for voltage at applicable fuse? The fuse is in underhood fuse box.
Hello Steve Grow,
In beginning electrics... to electronics
We call that an "inexpensive lesson"
"Beginning"... is where everyone starts...!!
No shame unless you FAIL to label your
take out PART as a "Good USED spare"
Date it and put it away... (USED: dated & signed).
If your car is a USA market vehicle...
Check out BBB Industries FREE wiring
diagrams and TECHNICAL SERVICE
BULLETINS..
(registration is required... the are REAL documents).
BBB Industries Premium Alternators Starters Power Steering Products
Fuse 34, 20 Amp... Interior, Driver Amenity, Cigar Lighter
Ground G201, (splice pack SP201)... Hope this helps.
Carnac the Magnificent
SOURCE: Where is the fuse box on 2006 Pontiac Grand Prix
yes it will fix your cigarette lighter. open the door on the drivers side and crawl in there and look up to your left it should be right there use a flash light .. good-luck ray
SOURCE: cigarette lighter socket replacement
You have to insert needle nose plyers into the socket and turn counter clock wise . hope this helps !
SOURCE: LOOKING FOR A FUSE BOX DIAGRAM FOR 2004 PONTIAC GRAND PRIX GT
It's under the hood, on the driver's side, under a square, black box with a lightning symbol on it. Loosen the flower-shaped screw that holds the lid of the box down, remove the lid, flip it upside down and when you look at the inside of the lid, you'll see a map of all your car's fuses. There's also a fuse diagram on the very end of the dash, but it's accessible only when you open the driver's side door. When you're driving, that end of the dash is blocked by the closed door.
SOURCE: How do I fix my cigarette lighter in my 2000
There is a fuse located in the "underhood junction block." The fuse is a 20A fuse, and is in cavity number 34 -- called the "AUX PWR/CIGAR" cavity.
The underhood junction block is on the driver's side of the engine compartment. There may even be some spare fuses for you to use in there.
SOURCE: 2003 pontiac grand am cigarette lighter does not work
no, are you checking the lighter with the ignition in the run position?
