Question about Locks & Locksmithing
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
  • 3 more comments
  • Anonymous Mar 12, 2014
    how can I change the code off my safewell elecronic safe with number 12823187?
  • Anonymous Mar 18, 2014
    How can I reset the security code?
    I have a safewell SE110021119 safe. I have forgotten the security code. How do I reset?
    How do I reset the code?
    What is the process to set up the security code?
Hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Posted on Sep 02, 2009
  • itah Nov 23, 2012
    I have a safewell credit card electronic safe ex2007.... the battery was dead and gone i had to use the overide key to open it. now, i have no idea how to set the a new passcode and program my credit card. my keypad has only numbers, * & #. no alphabets. pls help. thank you.
    New Friend:
I have a Safewell electronic safe EX20063232, somehow the code was released and I am trying to get a new code into the safe. The code 159 that comes originally with the safe works ok.
The instructions to change a new code say as follow: "Open the safe (it is open), press the red button and the yellow light goes on".
Here is where I have a problem; I don't see a red button on the safe.
Maybe someone could tell me where is the red button located?
Posted on Jun 05, 2015
Safewell EX2005327788
A set of emergency keys is supplied with every Safewell safe. In case the batteries drain out, you may use the emergency key to open the safe. These keys override the digital password. Remember, never keep the emergency keys inside the safe.
Jan 14, 2015 | Home Security
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Apr 22, 2014 | Computers & Internet
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
Hi I recently bought and installed a safewell electronic safe at my Residence the problem is this that I forgot the code of my safe and I did not know about the emergency key and it remained inside the...
If you did NOT change the code, you can contact the manufacturer and they may give you the factory preset code, but you will have to prove that you are the legal owner, most likely. Otherwise, it will be time to call your local locksmith that has some safe work behind him (or her).
Jan 22, 2011 | Safe International Digital Electronic Safe...
I have lost our spare key - where can I buy a
HUBBIE LET SAFE BTTERIES RUN OUT THE LOST BOTH KEYS ( BOTH ON ONE KEY RING??? )
NEED KEYS FOR A ..
NUTOOL SF10 ELECTRONIC DIGITAL SAFE..
HELP NEED PASSPORTS!!!!!!
JOAN
Jan 31, 2010 | Safe International Digital Electronic Safe...
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
Safe won't accept the code and the keys are lost
Without the keys and safe code you will need to call a locksmith. Even then they might be skeptical about opening the safe for you. There should not be any "backdoor" way of opening the safe for security reasons otherwise it defeats the reason for having the safe. I would contact the safe manufacturer for further instructions or you will need to cut open the safe if the locksmith and manufacturer cannot help you.
Sep 23, 2009 | Locks & Locksmithing
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
electronic keypad –159B. (These numbers are preset. You should change the code as soon
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
knob so you can turn it and retract the live action locking bolts.
Good luck
Sep 14, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
5,535 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
