PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Display resolution problemw with Dell Ins...
By skyryder on Nov 21, 2007
The only resolution that will fill the LCD screen is the highest one. When I select a lower resolution instead of filling the LCD screen is just displays a smaller viewing area with a black border around it, it does not fill the entire screen. If I hook up an exterman monitor I can adjust the resolutions and each one does fill the external screen completely. I have tried a new video card (nVidia) and it does not fix the problem. I have tried downloading the latest driver for the video card and that does not work. It did not used to do this and just started lately. Is the problem with the inverter board behind the LCD screen?
Same Problem
Jul 08, 2008
-   I have the identical problem with my Dell Inspiron 8000. I can function with an external monitor using Fn 8. But the screen on the laptop goes dark after a few seconds if I try to use it. Also, if it does stay, I get a visible screen which is too small to read on my 15' screen. It has black border all around it. How do I adjust the screen size on a Dell Inspiron 8000. On a traditional monitor you have buttons on the monitor which adjust screen horizontal vertical size and position. I don't see those buttons on my laptop Dell! -   montyhines
Jun 25, 2008
-   I have a Fujitsu LIFEBOOK C2220...The only resolution that will fill the LCD screen is the highest one. When I select a lower resolution instead of filling the LCD screen is just displays a smaller viewing area with a black border around it, it does not fill the entire screen. This issue happened after the laptop shut it self down and an "active desktop recovery error" appeared. Is there away to fix this?
-   docmc76
Dec 15, 2007
-   I have a Dell Inspiron 8000 with Windows XP. The only resolution that fill the LCD screen is the highest one and is almost impossible to read because everything is very little. The others resolution appears with black borders, how can I fix this problem?-   tamaramrm
Best Solution
posted on Nov 25, 2008
Very Helpful)
realty2inves
Rank: Apprentice
Rating: 100%, 3 votes
I had the same problem you described as small screen in the middle with black border around it. The only resolution that made the screen fill the LCD panel was 1024 x 768. THAT IS WRONG!!!
Dell Inspiron 8000
PROBLEM - Small Screen in the Middle
FIX THIS PROBLEM - Try (Function Key + F7)
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Sep 20, 2008
Somewhat Helpful)
hylan32
Rank: Apprentice
Rating: 75%, 1 votes
Are you kididng me? i'm only 17 and i have opened up all the LCD monitors in my Dell laptops without getting shocked. Not to mention I actually disconnected the inverter board on the screen of my Inspiron 1000 so i could mod the whole thing into a digital picture frame.
Was this helpful?
Yes
No
Solution #3
posted on Feb 11, 2008
Somewhat Helpful)
andrewpsp
Rank: Wiz
Rating: 73%, 58 votes
It's definitely an inverter board problem behind the LCD do u have warranty, b/c its always risky to try and open up monitor, by risky I mean, high chance of being shocked to death if you're not a technician trained for it.
Was this helpful?
Yes
No
Solution #4
posted on Mar 09, 2009
Not Rated)
rod_the
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem and here is how I fixed it (I have a Dell Latitude D820).
My XP is in french so the names could be a little different (free translation! hehe):
From
the desktop> properties> Intel (R) Graphics Media Accelerator
Driver for Mobile tab> Graphic properties> Display parameters
> Proportion options> Full Screen (without border).
You could also select the first option (keep proportions) if you can find the exact correct resolution for your screen.
Was this helpful?
Yes
No
Solution #5
posted on Jul 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this very same issue. There is aNvidia GeForce FX Go5200 Tab "Flat Panel Display" that was set to "Use Centered Output". Change the setting to "Use Display Adaptor Scaling". This worked for me.
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
thinkpad t60 battery, any recommandation?
Answer
I am in college, this would be my second computer (my current laptop is too cumbersome to carry), so... (More)
Answer
Computer no longer will boot up to windows xp.All I get is power light and a flashing caps lock... (More)
Answer
control key working fn key anf fn working control key function
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
