Question about GE Freezers
Outside of chest freezer gets hot
Was given a fairly new GE 7.0 cu ft chest deep freezer, the motor and outside of freezer gets very hot. Should I unplug it, is this a serious problem? It was in storage for about 8 months not plugged up.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
It is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Posted on Jul 26, 2009
SOURCE:
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 | Freezers
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hi we have recently moved to a house an we have inherited a fairly new whirlpool chest freezer which works very well but there is a lot of condensation on the outside which results in small pools of water...
The insulation between the inside and the outside of the freezer haas become water logged, This can be twmporarilly remedied by switching off the freezer and letting the insulation dry out for a few weeks, less in hot dry climates, but the solution is temporary and the problem will reoccur. To have the foam replaced means a complete strip down of the freezer and is seldom worth the cost. I am sorry, but you will probably have to get used to living with the problem. Incidently, it does make inroads into your electricity bills.
Jan 16, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
We have a general electric 20 cu ft chest freezer. the outside becomes hot to the touch is this normal?
Yes, the freezer / refrigerator is a heat pump, it transfers heat from the inside to the outside. Heat transfer effitiance is reduced if the outside is at hight temperature, so it is sudgested to allow free air flow for the back of the cooling device (where the radiator is )
Aug 05, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
My deep freeze locks on its own. We dont have a
nothing to do with temp changes. only to do with a broken lock mechanism.
Jul 26, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
Dec 09, 2009 | Whirlpool 14.8 cu. ft. Chest Freezer...
My Haier 7cu. ft. deep freezer gets hot on the outer walls. Is that normal? It stays hot all the time.
It 's builded that way so there's not condensation around the door frame and on the walls.
Nov 04, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Outside freezer storage
as long as it is just a freezer, not a fridge-freezer, should be no problem
Nov 26, 2008 | Magic Chef 7 cu. ft. / 198 liter Chest...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
2,050 people viewed this question
Top GE Freezers Experts
craig nesmith
Level 1 Expert
AJMAL KHAN
Gil Shultz
Are you a GE Freezer Expert? Answer questions, earn points and help others
