I have an old RUUD central AC unit that started blowing hot air. I set the thermostat to off and set the temp gage higher than air temp to turn the unit off and save money, but inside blower unit runs constantly. I'm trying to save money to have it serviced, but noticed my electric bill was higher that last month when the ac was working. The bill was about 4 times higher than the winter when ac is off and the gas heat kicks in. Can the blower running constantly cause this power usage and what is the solution (to save electricity), at least until I can pay for service?
  • 146 Answers
Hello
Okay did you check your thermostat to see if you have the fan switch on auto? The switch must be on auto or the fan will continue to run. If the thermostat fan switch is on auto then there is a malfunction in the thermostat probably. You can go to your forced air unit and on unplug the unit. That way it will not turn on at all, because the forced air unit is controlled by the thermostat. Hope this helps.
Posted on Jul 26, 2009
Engine cooling fan will not opperate
check that you have a thermal switch to switch on the fan and not a temp sender unit. One completes the curcuit when a set temp is reached ,the other is a resistance unit that lowers the voltage which in turn reads hotter on the gauge.
Jan 17, 2013 | 1996 Ford Thunderbird LX
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Ho to turn on central AC unit? (Ruud High Efficiency)
This is typical wiring for a 4 wire thermostat
R = Red One Side of 24 volt Transformer
G = Green Blower relay
Y = Yellow Cool Condensing unit
W = White Heat Furnace
Apr 28, 2009 | Ruud Heating & Cooling
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
