Question about SkyScan 86709 Atomic Wall Clock
Outside temperture my clock does not show outside temperture
  • 3 more comments
  • Gail Hescock
    Gail Hescock Dec 16, 2007
    Me too. No outside temp. Did you find a solution? Changing the batteries didn't work.
  • nancythomas Jan 03, 2008
    My outside temp. doesn't work on my clock either! Changing batteries didn't help either , changed batteries several times.
  • jlstru2000 Nov 05, 2008
    I have changed the batteries over an over again and the temp. still doesn't work I have also replaced the batteries in the time, its just the temp that doesn't work!
  • Anonymous Feb 05, 2009
    I have an outside temp. but its not correct. the true temp outside is 10 degrees, my skyshows the temp at 56. Ive tried to fix it over and over again.
  • Anonymous Mar 01, 2009
    We have replaced the batteries in the order it says on the back of the clock. We even went as far as to buy different brand batteries to see if that would fix the problem. Bottom line is this clock is problematic.
Pull batteries from clock and allow it to reset, worked for me!!
Posted on Apr 03, 2008
After changing the batteries on the outside unit, remove the batteries from the clock for a few minutes, then replace them. This will reset the clock to 'talk' to the transmitter.
Posted on Jan 10, 2008
Buy a new clock
Posted on Oct 06, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Posted on Jan 15, 2009
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Outside temperture does not display on clock
Make sure the out door sensor has fresh batteries, and that the clock inside is close to the location of the sensor outside so they can connect. If none of that works, time to replace the unit.....
Jan 09, 2014 | Homedics HMDX Eclipse Alarm Clock - Black
WATER COMING OUT OF MUFFER
This happens because of the difference of temperture between the hot engine exhaust and cooler outside tempertures. Its why you see exhaust during colder outside tempertures.
Mar 20, 2013 | 1997 GMC Jimmy
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperture is reading wrong
in front .....near hood latch/radiator
Oct 16, 2009 | 2004 Ford F150
Outside temperture
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Apr 21, 2008 | SkyScan 86742 Digital Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
460 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
