Question about Brother CS6000i Computerized Sewing Machine
Difficulty adjusting tension to avoid bobbin looping
I have a Husqvarna Sapphire 870 that adjusts tension automatically according to thickness of fabric. I have chosen woven heavy and am using 40 wt thread in bobbin and a heavier machine quilting thread on the to.
I am able to adjust the top thread tension digitally, and have tried increasing the tension from 4.6 to 6.0. incrementally. The looping is reduced a bit, but not entirely. I am not able to adjust the bobbin tension on this machine.
Any ideas would be appreciated.
    New Friend:
I am having trouble sewing anything and my thread is breaking! I have a viking and it does 24 different stitches! I have yet to be able to do one of them! This is driving me crazy! My bobbin just sits in the bobbin holder no wrapping or anything! Is this the way it should be? Please help very frustrating to have a new machine and not use it!
Posted on Jan 31, 2013
  • 55 Answers
It sounds like your bobbin tension is too tight. to adjust bobbin tension, remove bobbin case (remove needle plate first) and adjust bobbin tension screw on side of case until bobbin thread has a slight resistance as you pull it through the bobbin case.
this will be trial and error until you get best result. you should always try and match top and bottom threads. if the top thread is quite thick you may have continue to increase needle thread tension until balanced.
scott
Posted on Jul 26, 2009
  • Nicki davis May 09, 2013
    Thanks my machine has been a crock since i bought it 3 years ago and finally got it to sew thanks
Does Husqvana have special bobbin for bobbinwork? Machine is 180.
Usually, one will adjust the bobbin tension to accommodate heavier thread. If one does this often, a separate bobbin case set up for heavier thread is handy.
There are some links posted here:
Lower thread tension too loose Sewing Machines
that may be helpful in making those adjustments.
Aug 28, 2016 | Husqvarna Sewing Machines
How to change under tension on Husqvarna optima 190 selectronic
The bobbin has a tiny screw on the side that is the tension setting. Turn it a slight 1/8 turn and test (a small turn makes a big adjustment). Be sure to mark the original setting of the screw before making any adjustments so you can back out the adjustments if it's not working.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Aug 21, 2016 | Husqvarna Sewing Machines
Husqvarna sapphire 870 quilt
Could be several things.
First, install a brand new needle, perhaps a top-stitch needle will work better because it has a groove in the shaft that protects the thread. Make sure the needle is the appropriate size for the thread you are using--a needle eye that is too small will cause the thread to hang or shred. When the needle penetrates the sandwich, the top thread forms a loop. If the eye is too small, the thread will not come back up through the sandwich, leaving a loop under the fabric.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point and retest your machine on a quilt sandwich made of the same fabric layers as your project.. Tension problems are more evident when sewing multiple layers of fabric, so tweak the tension until the top and bobbin threads meet in the middle of the sandwich.
I don't believe you will have to adjust the bobbin tension, but in case you do, be very careful. Mark the tension screw setting FIRST so you can reverse any changes you make. Bobbin adjustments are made in very SMALL increments. Because I tend to use a lighter weight thread for my quilting, I have a specific bobbin case that is adjusted for my quilt thread and I keep my other bobbin for regular sewing. Then I don't have to keep adjusting the bobbin tension when going from sewing a quilt to something else.
Some machines do better with certain brands of threads than others.
Adjusting Sewing Machine Tension to Prevent Problems
Mar 02, 2018 | Sewing Machines
Husqvarna Sapphire 870 Quilt Sewing Machine While
Has the take up lever been replaced with the new updated one that does not let the thread slip out?
Oct 08, 2013 | Husqvarna Sewing Machines
I have a Husqvarna Sapphire 835, it is looping my top thread under the bobbin plate. I know this is a tension issue with the top thread but i only have one option to adjust it and it isnt working. I have...
I have a Sapphire 835 and am having the same problem with all the looping under the fabric. It DOES NOT do this while doing any type of sewing other than Free Motion Quilting. When I FMQ, I end up with a disaster. It is very frustrating, as that was the whole purpose for this machine. I have an older Viking and love it. So disappointed and don't feel that I should have to adjust/fix/fiddle with anything.
Jan 05, 2012 | Husqvarna Sewing Machines
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
May 29, 2010 | Husqvarna Sewing Machines
Huskvarna Viking quilters 850 I keep getting
it is a problem your tech can fix, ( should have been done when he had the covers off) but take it back in and tell him to adjust the sensor on the cutter so it doesn't rub and to clean the sensor. this will fix the problem
Oct 20, 2009 | Husqvarna Viking 1
Thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Mar 10, 2009 | PfaFF Creative 7570
Brother CS6000i Computerized Sewing Machine Logo
2,368 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
