Question about Numark ttUSB Turntable
Recording tracks from vynal stop recording after 1minute
  • 4 Answers
2 solutions, check all hook ups and make sure they ok, 1. see if your turntable can be played thru the stereo like amp or receiver with your audio cords and record that way to cassette tape. 2. if your turntable can go thru computer using usb cord and make sure you have download your software that came with your turntable if it didn't go store and like office max or simlair buy a product called inport deluxe by xitel
Posted on Jul 26, 2009
I have a de recorder 4050 when I try to put a track of a vinylalbum on cd, it stops after 20 seconds what can I do about it?
YOU mean "CD" recorder, right? A recorder will typically stop recording in the extended absence of audio.
And the track that is recorded - what does it sound like? If it's silence then you need to track your source back to its origin through the undefined electronics and find out why the signal isn't getting through to the recorder.
Jul 27, 2011 | Marantz DR-4050 2-Disc CD Recorder
You've recorded a track. You hit Stop. You want to capture more of the conversation in the room, so you FORGET to hit New Track, and instead push the record button. Which resets the already-recorded...
Yes, it's gone.
This is the one glaring fault with the 9600, if you select a previously-recorded track, and hit 'record', and then 'play', there's no failsafe, or 'are you sure?' prompt to remind you that there's already content within that track.
If you select the track, and ONLY hit 'record', putting the machine into record standby, but don't hit 'play' to start recording, your previous content is saved when you hit 'stop' - record standby doesn't overwrite anything.
Dec 08, 2010 | Alesis MasterLink ML-9600
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I want to know how to track c.d. when recording,I don't have a remote??
If you mean you don't know how to manually mark a track in Manual Mode >>while<< recording on the fly:
Toggle the Auto/Manual button to Manual
Press the SKIP/Search right arrow button for tray B while recording whenever you want to increment the track number.
Pausing or stopping the recording also increments the next track number. There is no way to manipulate the actual number assigned to any track. It is alway PLUS 1 from the last track.
I always use Manual track numbering on my Pioneer machine when recording analog sources because many machines (like yours) will interpret a short silence as a track break. This may not necessarily be what you want to happen.
Feb 24, 2010 | RCA CDRW120 2-Disc CD Recorder
It wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
Nov 20, 2009 | Philips CDR765 2-Disc CD Recorder
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
I need to know how to increase track external recording.
download a freeware program called "audacity" and use that to cut toe audio file up into seperate tracks.
Dec 24, 2008 | JVC XL-R5010 4-Disc CD Recorder
Don't know how to actually record
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Numark ttUSB Turntable Logo
107 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
