Question about Paini Spa Rubinetterie LaToscana 3 Piece Body Spray Kit
WATER IN TUB HOT, THEN TEMPERED
WHEN WE FIRST TURN ON THE HOT WATER TO FILL TUB, IT IS VERY HOT. COLD IS OFF. WITHIN 30 SECS. WATER IS TEMPERED. WE HAVE TO KEEP SHUTTING OFF THE WATER ,TO GET THAT BURST OF HOT WATER AGAIN. THEN PROBLEM REPEATS ITSELF. SHOWER BODY IS AN OLD AMERICAN STD. THREE HANDLE TYPE. SAME BOILER, LESS PEOPLE I HOUSE. HAD COIL IN BOILER CLEANED ABOUT 9 MOS. AGO, NO HELP. REPLACED WASHERS RECENTLY. DIDN'T HELP. ALL OTHER FIXTURES WORK FINE. I FEEL PROBLEM IS WITH SHOWER BODY, BUT I CAN'T FIGURE IT OUT. I'VE ASKED TWO PLUMBING SUPPLY HOUSES'. THEY DON'T KNOW. IF I HAVE TO REPLACE THE ENTIRE VALVE I WILL. IT WILL BE AN EXPENSE, DUE TO TILE & SHEETROCK WORK. TILE IS ALSO OLD. COULD BE LOOKING AT A TOTAL GUT.
  • 5,603 Answers
If you have a nearby single handle faucet, it may be cross tieing the hot and cold due to bad valve. This would be a real fooler!
Posted on Jul 26, 2009
    President:
  • 2,976 Answers
It sounds like you have an anti-scald mixer in the system that needs to be adjusted.
No Full Hot Water wash
the hot selection only tells the machine to turn on the house hot water to the machine
if you have it on warm , then both taps will be working
if you want a really hot water wash , there will be an element in the tub to bring it to temp
naturally an energy saver will not waste money heating hot water
Sep 15, 2017 | Washing Machines
Kelvinator Washing Machine only works when you fill it with buckets of water
Problem sounda like its within your valve . take off hoses in the back of washer and check for clog to the valve . if nothing found change out the valve. strange for both to fail but it can happen .
Feb 17, 2013 | Washing Machines
Installing a Miele WS5425 cold water fill only?
if you only want cold water for washing, just select cold wash in the program settings and turn off the hot water tap
so the settings you will be looking at are --like --
tub fill ---low water medium water or high water
water temp cold or hot
rinse hot or cold , wash setting --heavy , delicates , whites , woollens etc
may not be exactly worded like that but you get the idea
when ever you see wash temp or water temp , select-- cold
Jul 08, 2017 | Dishwashers
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 31, 2011 | Washing Machines
THE TUB OF THE WASHER GETS REALLY LOW WHEN IS FILLED WITH WATER. NOW, ALSO THE WATER DOSENT COME IN WHEN I TURN IT ON
All top suspend tub washers drop down when they fill with water. And they rise again when they have pumped the water out. This is normal.
What is not normal is water not coming in.'
check following:
Water is turned on
Remove inlet hose and run water to see if it is blocked.
Clean the inlet filters.
If you hear a buzz but no water goes in the inlet valve needs replacing.
If yu use only cold water try swapping the cold hose onto the Hot inlet. Then select Warm Wash.
Then only turn on the Cold Tap.
This will allow you to fill the machine and do a wash.
Watch out though when it comes to the Rinse position......some machines only do a cold rinse, and because you have swapped the hose over to hot it will not fill to rinse the clothes. Until you can get a Tech to do the repair you can just use either a bucket to add cold water for the rinse or use the garden hose to fill the tub with cold water for the rinse.
Have yu got all that?
Oct 25, 2009 | Speed Queen AWS75NW Top Load Washer
Our washing machine will not fill cold water. the
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. So, if you've confirmed the inlet screens are clear, more than likely you will need to replace the valve. If this is a Kenmore top loader, the following link explains how to replace a water inlet valve:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Paini Spa Rubinetterie LaToscana 3 Piece Body Spray Kit Logo
155 people viewed this question
Top Paini Spa Rubinetterie Home Experts
john h
Tom Chichester
Are you a Paini Spa Rubinetterie Home Expert? Answer questions, earn points and help others
