Question about Toshiba 57H81 57" Rear Projection Television
Toshiba TP55E51 blurred picture
The color is good but the picture is blurred
  • jagrat2k Nov 29, 2007
    poor focus
  • 87 Answers
You must be more specific with your description. Blurred? Like double images; or poor focus; etc.
Posted on Nov 25, 2007
  • Anthony Wilson Nov 30, 2007
    In your TV there is a component called a focus block. Most likely it needs to be replaced. Sometimes you can re adjust the individual focus controls for the red, green, and blue picture tubes. Remove the front grill and cover plate to expose the insides of the set. Look for a black plastic trapazoidial shaped part about the size of a pack of cigaretts usually mounted in the upper right corner. There are 6 controls, 3 marked screen and 3 marked focus. You will see anembossed letter above the control R,G,B (red, green, blue) Adjust the focus controls for each color. You should turn to a channel with a lot of print so you can see when your lines are sharp. DO NOT adjust the screen controls. If you dont have enough range on the control to achieve good focus and have the control pegged to the right or left it means the block needs replacing. If you can restore focus, it may last for a long time. Hope this helps.
Hi i Have a Toshiba 50H82 all the colors is good but the picture is really blur and shake, does someone knows of to fix it, im not shure if its call the tuner of the tv....
If the video is shaking, zig zag looking, etc your hypermodule has failed. This is common on your model. Some peeople call it hyper board, hyper module, etc..all the same.
You can get a repair kit for this from
Oct 19, 2010 | Toshiba 50H82 50" Rear Projection...
Red color is off alignment. Picture is blur. how to re-align color on TV?
Sounds like a convergence failure, here is a tutorial I made:
Let me know if I can be of further assistance.
Sep 09, 2010 | Toshiba TN55X81 55" Rear Projection...
I have red blur on the facial features of the people onscreen
This could be that your picture is just oversaturated. Try turning the color adjustment down slightly. If you make slight adjustments to the 'Contrast' and 'Color' you should be able to dial that out.
Jan 05, 2010 | Toshiba 32A33 32" TV
Color appears out of alignment. The set has
Replace the STK392-110 Convergence ICs and the 6 1.8 ohm 1watt resistors. You can get the repair kit whcih also contains the instructions from
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
Colors ore dull and blurred. how do i tune up
First start with cleaning all 3 lenses on top of tubes,then clean mirror,If picture is still blurred you may need to change projection Fluid in Tubes.
Aug 07, 2009 | Toshiba 43H70 43" Rear Projection...
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 50HP16
"Popped"? That sounds like a serious issue that is going to require a warranty repair or a professional TV repair person to address.
May 01, 2008 | Toshiba 50HP81 50 in. Plasma Television
Toshiba 57H81 57" Rear Projection Television Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
