Question about Garden
The string is stuck will not pull out to start
  • 636 Answers
Try tapping the head a few times on the pavement if this doesn't work you may have to take the head off.
Posted on Jul 26, 2009
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pull string is stuck....very difficult to pull.
Yep, starter pawl spring or pawl itself. I don't know what trimmer you have but most are set up like this. Something engages the flywheel so you have to start there.
Sep 07, 2014 | Garden
I cant pull the string to start the mower
pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
Aug 30, 2014 | Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
HI I BOUGHT A 1969 TALKING SERVICE STATION BUT THE PULL STRING IS JAMMED PULLED OUT HOW DO I FIX THIS AND GET IT TO TSLK AGAIN
mcdevito75 here, you may not be able to as the spring on the pull string may have lost it"s tension or the pull string mechanism is just stuck. You may not even be able to get at the mechanism if it"s a sealed unit, if you can get at the mechanism a little penetrating oil may help. Contact the toy manufacturer online or phone for more help.
Jun 26, 2010 | Toys
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
The string in the spool of the weed eater is stuck. How can I remove the string and how can I avoid this problem in the future? I'm using the pre-cut strings. Thanks
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
Sep 20, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
