Question about Dometic RM2652 Refrigerator
Dometic refridgerator won't stay lit on Propane
Propane tank is full, all other propane appliances work fine but the fridge will stay lit anywhere from 2 hours to 2 minutes then shut down with an error code. I want to replace the thermocouple, but this fridge doesn't appear to have one. Where is the thermocouple or temperature switch that detects when the propane is lit?
    Problem Solver:
  • 9 Answers
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
Superflue. Why doesn't it stay lit?
If this is in a RV there is a propane monitoring valve. It will close and cut of the propane if it is not being used for a period of time or if there is a leak. The valve is mounted between the propane tank and the first appliance, usually inside the RV.
Mar 09, 2016 | Water Water Heaters
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Will not stay lit
The pilot sequence is designed to run for 45 seconds. It could be that the thermocouple is not triggering the cycle once the pilot is lit. I am having the same problem and intend to replace the thermocouple and then give it another go. The fridge works fine on electric but stopped working on gas last week.
Jun 29, 2009 | Dometic RM2852 Refrigerator
Why is it difficult to light our dometic refrigerator, when using it on propane?
Hi: In my travel trailer I find it is easier to light my Dometic if I bleed the lines by starting my stove top. It uses a lot more gas to get lit and floods the lines with propane. Your fridge uses such a small amount of gas it takes a long time to bleed the line to it. Don't focus on just the oven.... run any propane appliance on the way to it first. I hope this helps, Jeff
Jun 12, 2009 | Dometic RM2620 Refrigerator
Gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
If you need further help, reach me via phone at https://www.6ya.com/expert/jeremy_075aa344198c3329
Feb 20, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Dometic RM2652 Refrigerator Logo
1,461 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
