How to open door on front loader when unbalanced. Nec Nfl 1065.
  • carolb45 Jul 26, 2009
    Thanks Mike. Unfortunately it is built in under a bench and I can't reach the power point without moving the machine. Bit hard when full of wet clothes. Ta anyway.
    Yep. No probs. mate. Will do that now. Thanks
  • 636 Answers
Unplug the unit for a couple of minutes and try it
Posted on Jul 26, 2009
  • mike fuson Jul 26, 2009
    Do you know were this breaker is for it ? works just as well.
According to wife it had the load unbalanced code and a minor leak then turned off. Now won't turn on. I'm an automotive Tech so any help in how to properly diagnose Ready with multi meter in hand
that water leak is a concern if near electrics
the motor may have over heated
if it is a top loader
would say too many clothes/water ratio in the machine
if a front loader
see if door safety switch is faulty
look over the door seal
turn off at the wall
multi meter the plug to see if there is continuity between the pins
including the earth
plug in try to set up a cycle
Aug 18, 2016 | Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Washer shakes violently!
Do you not know that unbalanced dry clotrhes become super unbalanced wet clothes! If you put too little clothing in the front loader, the weight will be in one place on the high speed turning drum. If you put in too much, the load will shift to a few locations but still be out of balance. Rather than "dance" the Chubby Checker way with your machine, try stopping it when it does "the dance" and redistribute the clothing around the drum!
Dec 26, 2012 | Dryers
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
I have a maytag front loader that is unbalanced not to sure to unlock machine to adjust clothes?
If you can, disconnect the drain hose and drain the water into a bucket by lowering the end of the hose into it. once most of the water is out the door should open and you can take some clothes out. Try not to overload the drum.
Apr 21, 2012 | Maytag Washing Machines
Nec mt-1065 lamp hours reset
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention.
Oct 25, 2010 | NEC MultiSync MT1065 Multimedia Projector
Unbalanced load, sign UE is on, cannot open the door
UE:
• The load is too small.
• The appliance is tilted.
• Laundry is gathered to one side.
• Non distributable things are put into the drum.
See page 17
Apr 19, 2010 | LG WM-2277HW Front Load Washer
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
NEC NFL-1065 washing machine won't drain or spin
I had the same problem , I replaced the pump havent had the problem again. Then the heater element blew, (kept triping the house fuse) replaced that, then the door would'nt lock everytime, now it will fill up then give a code "E8" I think it's the mother board
Oct 25, 2008 | Washing Machines
The water wont drain out off the washing machine there is an error code UE is flashing and it wont finish spinning i have taken off the drain pipe and its not blocked and i have emptied the water via the...
YES ! there is something else , check the little MOTOR that is attached to the drain hose , take it out , take it apart and check if there s some stuff blocking the motor inside ,hopefully this will take care of the problem .
Apr 17, 2008 | Washing Machines
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
