Back to:
Tags:
Nakamichi PA-504 Car Audio Amplifier
I do not hear any music through my 10" M Audio Subs...
posted by shanthy on Nov 21, 2007
Greetings from London UK. I got NAKAMICHI MB100 HU, powered by NAKAMICHI PA1004 Four Channel Amp which powers all the front door & rear Shelf Speakers and touch wood, still working fine without any problem. I do have a pair of 10" M Audio Sound System Subs which I've powered via another NAKAMICHI PA350 Four Channel Amp. Please note the M Audio Subs are dual coil each hence need 4 channel amps to power both. All were working fine until recently Subs is dead - could not hear any music BUT I do hear a hump on a timely interval, say within every minute (just Clicking noice such as BUG..... BUG). Any advice? I do not know whether the Amp is blown but I do get this Hump noice - which I believe the Amp is receiving power. Please help me as I'm going mad without the Subs. Thanks in advance.
Comment by shanthy, posted on Dec 08, 2007
Well, I'm planning to upgrade my incar head unit by installing Nakamichi TP1200 etc. I need a nakamichi professional who could get the fitting job for me. I live in London nevertheless am prepared to travel to a reasonable distance to greet my nakamichi expert to get the job done. Please let me know if you know someone over here who is a true professional and love his job and not purely the charges. Thanks in advance.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 22, 2007
Thanks for Trying (70)
dan12345
Rank:Guru Guru
Rating: 87%, 49 votes
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
You mentioned you need a 4 channel amplifier make the two, dual voice coil subs operate. The is not true and by hooking them up like that, there's a chance of damaging the subs. The reason is that the dual voice coils are interwoven and they have to get electrically identical signals or they fight against each other. The can mechanically fail, then, electrically fail, then even damage the amp too.
Rating Locked! (?) shanthy has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I do not hear any music through my 10" M Audio Subs (M Audio Sound System):
I don't want to Accept this solution
Can you Help with these Car Amplifiers problems?
Car Amplifiers
my anp works fine. but when i bridge it. it seems to melt...
Car Amplifiers
I need a schematic for an MA 744C amp from Majestic. It...
Car Amplifiers
I have a bad speaker amp, part # 35678907. I ordered a...
Car Amplifiers
311
Car Amplifiers
in need a wiring diagram for my amp if you do not mind...
Loading problems.
Repair Service
Find Car Amplifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
