Question about Sharp Aquos LC-32D40U Television
Performed ground repair, now screen is blue, sound ok
Aquos LC-32D40U, Screen would go black. Performed suggested repair to Inverter board grounds. After reassembling I now have a blue screen, sound ok. Did I miss something or possibly plugged a connection in wrong? Also, is there a reset button on this unit? Thanx.
  • mcolden Jul 26, 2009
    Thanks, it was a ribbon connector. steel color multi blue and black wired. upside down, once i connected it correctly, all is working well. Excellent source for info.
  • 2,318 Answers
I would suggest to check the wire connecting the main board with the LCD controller board. It might have been disconnected when repairing the ground connections.
Posted on Jul 26, 2009
  • Jaime Hernandez Jul 26, 2009
    I forgot to say to press input to select a different input before opening the TV again. Also press menu and see if you are getting OSD, if not then the LCD controller board is not connected properly or not connected at all.
Sharp Aquos LC-40C32U: Black screen, various vetical colored lines for extended period after turning tv on (volume button changes appearance of vertical lines)
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots do defective LCD panel are given. You can see and compare it to that of your TV's.
Apr 21, 2014 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC C3234U screen goes black, audio is still good, turn to another channel far away from the intended channel & it will reset. More often as time goes on.
Ur LCD inverter board it dead,replaced this LCD inverter board will get ur picture back.It long board in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Mar 31, 2010 | Sharp Aquos LC-C3234U 32 in. LCD TV
Screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp aquos model LC-32D40U screen goes black
The Sharp TV model LC32D40U / 41U "Black Screen problem" is a very well known issue. The inverter is losing ground contact which will prevent the back-light from staying on. The solution is to re-tighten six screws on the inverter board. You also would want to clean the copper contacts on then bottom of the inverter where the screws go through. Access to the inverter board will require some disassembly. Plan on taking at least three hours to repair. See the photo for the location of the screws. Use some "blue" locktight" on these six screws. There is actually a Sharp Technical Service Bulletin that describes these screws. Sharp wants you to replace these screws with a newer version. They cost at least $2.50 each! I think my method will work just as good using the "Locktight"_548.jpg_547.jpg
Apr 20, 2009 | Sharp Aquos LC-32D40U Television
I have the same model TV that is 18 months old. The repairman wanted $365.00 to replace the inverter and update something on it. From what I have seen online, it is mainly just loose screws on the inverter. I called Sharp and they are paying for the repair on the TV
Jun 30, 2008 | Sharp Aquos LC-32D40U Television
TV No Picture
Sounds like overheating. Is it physically mounted according to instructions so that it can "breathe"? Keever
Mar 06, 2008 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Jan 10, 2008 | Sharp Aquos LC-32D40U Television
Probelm with wide screen display .
Check your VIEW MODE button instead ....
Aug 17, 2006 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
566 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
