No RGB Signal. Power will be turned off. - Televison & Video
  • cmhartman Jul 26, 2009
    Back up and running. Must learn to leave remote on a surface other than my body. Thanks much.
    This problem took maybe 30 minutes for the correct solution from you. Will use your firm again whenever I have a problem.
  • 2,200 Answers
Hi
If your TV has been put into AV or S Video mode by mistake this will happen. To correct this you need to push the button marked TV on the remote to change the mode back to TV.
If your remote does not have this button you will need to open the settings menu using the remote and check through the Audio settings and re enable RGB or TV mode.
This will resolve the problem.
Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 26, 2009
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
Thompson Wysius 42" plasma woes
did u try a different connector of cable?
Jun 12, 2008 | Thomson 30LCDB03B 30 in. HDTV
Rgb no input signal computor stars up on for a few mins then goes blank and a sign saying rgb no input signal
Have you tried to disable the Power settings? For that go to Start, Control Panel, Power Options and in there put everything to Never, click Apply and OK.
If it happens even after that then the video chip is dying and it will have to be replaced - you will need a new video card.
Jun 17, 2011 | Computers & Internet
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
Jan 02, 2010 | Vizio VX37L Television
My vizio Tv keepssaying there is no RGB signal and the power will turn off. Any idea what this is or now i could fix it? thanks!
rgb is input that usually comes from a computer. if there is an extended amount of time, the computer goes into hibernation. also most newer tvs go into hibernation themselves if there is no input.
possible simple solution is that you move the mouse or hit a letter on your keyboard to "wake up the tv or computer"
would be nice if vizio put a rgb button on the remote. having to go to input then scroll down just sorta blows.
Dec 06, 2009 | GE 13TVR70 13 in. Combo
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Monitor "No Signal" RGB Box
I've been told it may be the power supply.When I get time I am going to change mine,if it works I will let everone know.
Jan 02, 2008 | Computers & Internet
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
