Question about Toshiba Computers & Internet
My toshiba A200 the monitor are dead no backlight....
  • 744 Answers
Hi..
The monitor might be 'dead' because the flyback transformer (specially primary section of it) is not working. You can try replacing it if it doesn't cost you too much...
thank u
rate me
Posted on Jul 26, 2009
Toshiba equim has ablack screen
Assuming the laptop IS running at least the POST tests:-
1. Try shining a torch into the screen t see if you can see any figures or characters. If so, your backlight is defective.
2. Try connecting an external monitor via the 15 pin D-type connector usually found on most laptops. If it works, get into the BIOS to check he BOOT SCREEN setting is set to LAPTOP LCD or LCD+EXT. If the LCD is dark in any case it could be the graphics chip OR the LCD is faulty.
Sep 21, 2014 | Toshiba Equium A200 Series Satellite A205...
Toshiba Satellite A200-FE008C bios update failed
You can't. The mother board is now dead. You will need a new bios chip.
Jan 22, 2014 | Toshiba Satellite Pro A200-EZ2204X...
My Toshiba L645 laptop has power but the screen is blank do you have any suggestions that I can try.
It could be a couple of things:
1) The backlight could be dead:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
2) the LCD itself might be dead, try connecting an external monitor.
Dec 30, 2013 | Office Equipment & Supplies
Toshiba satellite pro A200 board dosn't display
In that case it is The Video Graphics Card near the processor ic. Have you tested it with a external monitor? that will prove if the chip is good or bad.
Apr 11, 2012 | Toshiba Satellite Pro A200-EZ2205X...
Toshiba Laptop A200-AH5. My computer seems dead and there is only the blue (I think battery light) light that is on. Nothing else works. I hope my laptop didnt crash? Please help me.
Most likely the problem is related to the board. Also most likely the light you are seeing is the power light. Do you get any blinking lights? Try also an external monitor and see if that works.
Apr 14, 2011 | Toshiba Satellite A200 AH5 (4400 mAh)
Toshiba A200 Notebook Computer Screen Black Out
LCD monitor work based on backlight illumination, they have a fluorescent tube of high intensity usually located at the bottom ot top of the monitor sometimes they may even have two of these one on each side or on top and on the bottom of the screen, this tubes illuminate the screen from the side into the LCD device. The lights are powered by a high voltage switching power supply. A number of things may happen that can cause the symptons you are experiencing. You may have a bad high voltage power supply (locvated inside the laptop body or sometimes depending on the model inside the actual LCD lid.), you may also have a bad light tube or a bad flat cable that connects from the power supply to the LCD lid. Usually is not worth to pay for a repait like this as it is time consuming to dissasemble the whoel laptop to fix or replace any of the components involved in this. If you want a fast and cheaper solution, get a cheap LCD monitor and conenct it to the external RGB port of yoru laptop if you want to keep using it. Otherwise look for replacement parts online for the light tube, power supply assembly and cabling then get somebody to replace them for you.
Jun 02, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba a200 laptop Have black screen even tho laptop has booted up, going by the usual sounds.Took battery out and used ac adapter, but same problem.Switched power off several times, left off over night...
You could have a defective screen - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba A200 laptop
Can you still see a faint image if you look at the screen closely? If so, you just don't have backlight and you should check your inverter. he part is available on common auction websites so you can try the repair yourself. There are also independent Laptop Repair places that will replace the inverter or check what else could be wrong Laptop Repair NYC.
Nov 06, 2008 | Asrock GE PRO-M2 Motherboard
Computers & Internet Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
