Question about Saws
I have a Skilsaw Model 77 Type 16 and I need the power switch
I have a Skilsaw Model 77 Type 16 and I need to locate a replacement power switch
    President:
  • 583 Answers
I think skil was taken over by ryobi some time back
Posted on Jul 26, 2009
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
Center bolt spins freely
There was probably a hole in the flange that you discarded that was used to put a pin/ nail/ bolt/ etc in from the body of the saw to hold that flange from turning while you did the nut up. Unless that hole is there you will have no way of holding the shaft to tighten the nut.
Jul 27, 2013 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How do I replace the spring on the retractable blade guard on a model 77 worm drive skilsaw?
Bearings maybe......I'd also check the armature fan and see if it came loose. Either way it doesn't sound cheap!
Aug 07, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skilsaw motor runs blade won't turn
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Jun 27, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Manual for Skil Saw model 77 type 17
I have a Skilsaw model 77 type 16. I have the original owners manual and would be willing to fax you a copy.
The manual only lists a part number for the gear oil, it is No. 249. This is for a 5-3/8 oz tube of gear oil. I checked with my local hardware store which services this saw and they called a factory rep. They told the hardware store with shipping and handling it would cost about $17 for the oil! However they also said that a 90 weight gear oil is close enough to solve the problem.
Hope this helps.
Sep 22, 2008 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Saws Logo
328 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
