Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
How do I connect the DPR 1260 d-link router to make it print from my laptop? I plug all the necessary wires into it, but it won't print wireless from my laptop. What am I missing? I don't have the directions anymore.
  • 797 Answers
Can you see the print server from your laptop? You should be able to find it in Network Neighborhood it should be listed as http://dlinkps-XXXXXX where xxxxxx is the last 6 digits of the mac address printed on the label on the print server. Open a browser and enter http://dlinkps-XXXXXX and you should be connected to the print server web interface.
Thanks, Jim
Posted on Jul 26, 2009
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connecting this print server
try unplugging both and then plug in the router,let it reboot, then plug in the other and let them find each other. if that doesn't work let me know.
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DLink DPR 1260 lost connection
Are the small printer icons lit up on the face of the PServer? Mine has recently started losing connectivity and simply unplugging the power and plugging it back in restores full function. Still looking for the reason it just started doing it though..
Mar 17, 2009 | D-Link Computers & Internet
Hi!!! How do I set up wireless printing? I have an HP1022 printer...
You should have your DSR 1260 connected via cable to your router. Open a browser. Go to http://dlink-xxxxx (xxxx=last 6 digits of your 1260's MAC address) or http://192.168.0.10. The DSR 1260 web config screen will open. Click on the Setup tab (top row). Then click on Wireless Setting on the left hand column menu. Select settings based on your router's setting, Typically: Wireless Setting: On; Network Name: choose from drop down, if not there, type your router name in; Wireless Mode: Infrastructure; SuperG Mode: same as your router; Security: same as your router. Then Save.
Remove the cable connection of your 1260 and your router. Then go to Status in the web config. Click on Wireless. It should now show your router details. That's it.
Jan 24, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
489 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
