Hi there I have no lcd display I have check fuse on power board Im getting 240v to the board also check connector to lcd main board that is getting 24v. Is ther anything else to check cheers Antony
  • antonyskydiv Jul 26, 2009
    no its not a tv its a digital reciever grundig dtr 2544 model it connects to you tv
  • antonyskydiv Jul 27, 2009
    the unit is a set top box it does not display the lcd I have gone over the soldered joints to check for dry joints but still no joy could it be a board fault ?
    President:
  • 2,185 Answers
If it is turned on but without display, then there is a problem with the backlight of the LCD monitor.Here is how you can replace the LCD.
http://inventgeek.com/Projects/BacklightFix/Overview.aspx
But you should be highly experienced with this stuff to do this, otherwise, you can bring it to an authorized service center. If its still under warranty, the better.
Posted on Jul 30, 2009
    President:
  • 2,559 Answers
Check the capacitors for damage and soldier joints for proper connection
Posted on Jul 26, 2009
    President:
  • 2,187 Answers
It appears that you have checked a lot of components, have you checked the continuity? There may be disconnects somewhere that is not visible. It could be the IC for the output that may have gone bad.
Posted on Jul 27, 2009
  • 3,037 Answers
This is an lcd tv right? If so then shine a flashlight into the screen and see if you can see an image. If you can, then your backlight or your inverter for the backlight went out and need to be replaced. If it isn't an LCD tv, let me know. Also if you find that the above is not your problem, then please let me know the make and model number of the tv along with whether the tv has audio still. Let me know how this turns out.
Benjamin
  • Benjamin Patri
    Benjamin Patri Jul 26, 2009
    Do you have audio or any type of picture on the tv with the digital receiver?
  • Benjamin Patri
    Also, have you connected the receiver to any other tv to see if it will work? Please try this so we can determine whether the tv or the receiver is at fault to start with.
Display panel on my Bosch washing machine does not work l have checked the out let and confirmed that there is mains power (240V) all the way to the back of the display panel.
240V does not turn on the display panel you should check the transformer on the board or next to it or check a fuse on the board
Feb 09, 2014 | Bosch Washing Machines
Nokia 2730 white display problem
Hi.Most of this problem comes from the display connector.But before you check this area change now lcd and try if the problem still persist change the Display Connector which is attatch to the main board.Good luck.
Oct 11, 2011 | Nokia 2730 Cell Phone
Im getting sound but no picture
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
take care in handling the set....
Aug 04, 2011 | Maxent Televison & Video
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony MHS-CM1 HD AVC Camcorder
XEROX Monitor Product No : XM3-19W Model No: 900W Power: AC 100-240V 50/60Hz 1.2A Problem : " RGB Analog " When Starting the monitor afte 3 second display and then Black screen.
Common failures in LCD monitors are due to bad caps as hown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 06, 2010 | Xerox XG-91D 19" LCD Monitor
Hi, no display on any led. 240v to machine sounds
It does sound as if the door latch may be at fault but it also seems as if it has caused the main control P.C.B. and control Interface to fail.This machine was manufactured in April 2005 from the Prod. no.This is covered under the major parts warranty (not the door latch).Also make sure if the power to the controls is off check for any loose connectors on the main p.c.b and interface.Also have a look at the body of the door latch and if there is a brown discolouration that is a good sign that is the culprit.
May 03, 2010 | Zanussi ZWF1440 Front Load Washer
Won't power up. Press power button, turns green then orange.
Good day sir/maam, Hi, If the LCD is under warranty, use it, they will replace the LCD monitor for free. If not, you may need spend for a Power supply board, to repair one.
There are two boards usually found on an LCD monitor, one main board that controls the LCD screen, back light, inverter, controls and sound. the second board is the power supply board, which accepts mains voltages 90v-240v AC and convert them to DC to power the entire monitor.
If however you may bring it to a repair shop or dealer, they will replace the power board, and there you go. the monitor is done.
Nov 24, 2009 | BenQ FP737S-D 17" LCD Monitor
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
