Question about Sport & Outdoor - Others
Yamaha 200Hp 2 stroke - coils on port side not firing
  • adventurediv Jul 26, 2009
    It was running and then the stb coils shutdown, we replaced the CDI Unit and rectifier and it changed from stb to port. We have also run with the control unit disconnected and no difference.
  • 285 Answers
You will need to remove the coils which are not firing and inspect them visually. If there are any signs of cracking or other abnormalities, they will need to be replaced as they are faulty. Coils are not something that can be easily repaired if they are internally faulty. They are a replacement item. Also check you have a good ground point on the on the motor and that it is clean and secure.
Posted on Jul 26, 2009
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Nov 09, 2012 | Clymer Marine Maintenance and Repair...
Only firing on two cylinders on the right side the motor. i checked the coils and they are working. i am wondering if it could be the power pack
have you sorted it out yet as just curious as to what the fault was also this new web site leaves a lot to be desired for finding the latest questions as they come in
Jul 06, 2011 | Clymer Marine Maintenance and Repair...
Xs750 what is the firing order
There is no firing order. Your bike has a coil that fires on both the compression stroke and the exhaust stroke (also called a wasted spark). Therefore either plug wire can go on either cylinder and the bike should run the same.On four cylinder bikes this meant that you could run four plugs using only two coils and two sets of points instead of four coils and four points.If the bike is running poorly try new spark plugs and new spark plug caps first(start with the cheap stuff). Next check the actual coil and pulse pick up or points. You may have to replace the coil only because the wires are cracked shorting.
Jul 25, 2010 | 1979 Yamaha XS 650 SF
WHEN CHANGING THE PLUGS, DO THE WIRES GO 1234 OR IS THERE ANOTHER CONFIGERMNT?
You got the wires right, but the coils might be off, I think the 1 and 4 and then 2 and 3 fire. Something like that. I don't know for sure. I'll send you the site. Hope this helps.
On a bike like the R1 that uses 2 coils to run 4 cylinders, most always 1 and 4 run off of the first coil, and 2 and 3 run off of the second. Both cylinders run buy the same coil fire at the same time, even though they are not both on the power stroke.
The motor will still run with the leads to the coils reversed, but runs much better when they are on correctly.
Jun 10, 2010 | 2001 Yamaha YZF-R1
I have a yamaha 200hp 2000 model vmax outbaord that lost fire on cyl 2 and 5. the coils are fine and my manual doesnt have a way to ohm test and check resistance on stator and trigger to see which...
I am going to try to help you although I have never seen a similar motor. If you have several cylinders that work, aren't some of the components the same? You could switch components and trace the defective part that way. I.E. if #2 and #5 are dead and you switch components to make #1 and #6 dead you will know. Also if the peak voltage reading test is something you can do, you would not have voltage without continuity. You said you lost fire so you would not be able to measure ohms or resistance with a break in the circuit anyway. Hope this helps you.
Apr 01, 2010 | Boating
Yamaha 200HP, HPDI lifts out of the water when shifting
sounds like something got put together backward . most motors will lift when put in reverse if not locked down . this is to prevent getting swamped by the rush of water going backward .
Mar 13, 2010 | Boating
Cam timing my 2003 yamaha yz450 how do i do it
take magneto cover off find tdc on the magneto and look at the cams it should be after the inlet valve shuts and goes on the firing stroke just put a rod in the cylinder and see if the piston reaches the top off the bore when the magneto is at tdc then its fine buddy any probz im here to answer
Oct 08, 2009 | 2003 Yamaha YZ 450 F
Firing order for yamaha xj650 1981 motor cycle
without a manual can you set-up the timing mark on flywheel
an see what cyl is compression stroke to find #1 cly
coil 1 are spark wires 1 and 4 cyl
coil 2 are spark wires 2 and 3 cyl
now if still have trouble then (if same plug connection) switch the around inlet plug on coils form bike wire harness or swap spark wires
Apr 10, 2009 | 1981 Yamaha XJ 650
Sport & Outdoor - Others Logo
51 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
