Question about Brother CS6000i Computerized Sewing Machine
Persistent E1 message
My machine was working fine, then it had a thread tangling issue while a friend was using it (possibly due to incorrect threading?). Now it gives the E1 message when I push the pedal. Troubleshooting guide says this means you need to put the presser foot down, but it IS down. I have checked the threading, needle, bobbin case, etc. and can't figure out what is wrong. Any thoughts would be much appreciated.
  • 55 Answers
Some machines have a presser foot sensor or switch which prevents the machine sewing if the foot is not down.
if your presser foot is down and you still cannot sew the switch or switch actuator is most likely damaged. you will require a tech to repair this.
scott
Posted on Jul 26, 2009
I folded over a terry cloth towel and now my machine isn't working right?
The thread is incorrect for material.
: or incorrect size needle or it is bent.
:Not threaded correctly.
Thread tangled around the spool holder.
: Thread too thick for needle or too thin.
Hope one of these helps.
Feb 10, 2015 | Kenmore Sewing Machines
Brother exedra E-40 why it alway get tangle and brake the threat?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2014 | Brother Industries, Ltd Brother Sewing...
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Singer Merritt 2430
Hi!
There could be several reasons due to which the thread keeps bunching up underneath.
It may be due to tangling of upper thread. Remove the thread completely from the machine, use correct size spool cap for the size of the thread spool, re-thread the machine, now remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please rate the solution as FixYa and revert for any clarification.
Thanks
Rylee
Apr 23, 2009 | Janome 6019QC Mechanical Sewing Machine
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Janome 9000
    The heavy "knitting" on the backside of the fabric sounds like a tension issue due to your thread catcher or other. You may want to look at this link:
    http://reviews.ebay.com/SEWING-MACHINE-COMMON-TROUBLES-HELPFUL-HINTS_W0QQugidZ10000000007548289
    The fuse issue may very well be unrelated, just coincidental.
    Aug 19, 2008 | Janome Memory Craft 9000 Computerized...
    Thread tangles around shuttle
    are u talking about 3-4 uses from being a new machine or is this a machine you aquired,,,,alot of times the machine can be off timing, if this is not the case always try fully unthreading and rethreading and please use rayon or polyester thread, plus make sure you have the bobbin case in correctly
    Jan 20, 2008 | Singer 3116 Simple
    Brother CS6000i Computerized Sewing Machine Logo
    398 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
