Question about Garden
My snapper won't pull forward but will back up
I don't know whether to look at the clutch or the axle
    President:
  • 1,273 Answers
You're in luck, if your Snapper is of the type with a record player drive. Let me explain myself. Look under the motor. You should see that the shaft connects to a disc that has a rubber coated drive disc (or tire) under it. Works like this: when you are in the forward speeds, the tire is on one side of the disc. When in reverse, the tire moves to the other side. This means to me that it is neither your clutch or axle. Snapper dealers sell a tool that allows you to adjust the friction of the record (disc) against the drive wheel (tire). You loosen two allen screws on the disc where it mounts to the motor shaft, and the special tool screws into the center of the disc. With the tool installed, you screw down the jack screw to tighten the disc against the drive wheel. You then tighten the allen screws back up and you're done. Sounds too easy, 'eh? There are other variables you'll need to consider, mostly the condition of your drive wheel. The rubber on it will wear over time, so look at it carefully. If it is cracked or damaged, it should be replaced. It's easy to do. What about costs? Good question.... It's been a while, but best I remember, the speciality tool is ~$20. You'll need a long allen wrench to fit (~$2), and maybe the drive tire (~$15). The best news is that the speciality tool lasts virtually forever, and you'll use it again if you keep your Snapper
Hope that you have found this to have been helpful.
Best regards, --W/D-- Please feel free to rate this solution!
Posted on Jul 26, 2009
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
Hyundai Elantra clutch Pedal Stuck Up
The axle job should not have caused any problem to develop in the clutch.
I don't see how they could have.
If you can work the slave by hand, it may be a problem with the clutch master cylinder. Maybe the rod from clutch pedal into the master is bent or binding up and won't travel into the master. You could check if master operates easily by taking line off at the slave cylinder (or if not able to remove hose, then open the bleeder valve on slave) and see if your pedal operates now. Use a can to catch fluid if you don't want it to spill on floor. If the pedal still won't move it must be a problem with the master cylinder or the clutch rod.
If the pedal works with line removed, or the bleed valve open, then the release bearing inside the bellhousing must be binding up and not moving forward to engage clutch. (The slave cylinder pushes the clutch fork lever which pushes the release bearing forward on a shaft up against the clutch pressure plate to allow the clutch to operate .If the release bearing is the problem, the transaxle will have to be removed to fix it.
As I said, though, if you can operate the slave and the cllutch lever it pushes with your hand, it doesn't sound like it is binding down there. Check the pedal's push rod going into the master cylinder. Good luck.
Jun 01, 2012 | 2001 Hyundai Elantra
Snapper riding mower runs but wont pull itself
first check the friction wheel that drives the rear axle then look at the cable adjustment you may need to move the small rings around the pedal if all that looks good loosen the pulley assem away from the engine closer to the axle
May 16, 2012 | Garden
Snapper 3011X6S will not go
you may need to move the spacers on the clutch cable or the wheel on the engine may have slid up on the crank if so loosen the two set screws and pull it down a little
Mar 30, 2012 | Garden
Troy-built 21" mower - self propel problem. From my research it seems like a manufacturer problem that was availiable thru a claim but I am the 2nd owner so I must fix myself. Its a model 834. I have...
do you have the complete model number from the data tag on the mower frame? there are two typical systems for these machines, both require the belt to be tight and not slipping at the crank shaft, and the pulley on the trans-axle to not be slipping on its shaft, the older style trans axle uses a belt tensioner system to tighten the belt and turn the pulley, i.e. if the pulley turns then the axle should too. this can be checked by hand with the axle and belt removed. the second system is a clutch style axle that has a constantly tight belt and uses a small cable controlled lever on the transmission housing to engage a drive clutch inside the transaxle, if moving the lever forward doesn't cause the axle to turn as the pulley and shaft are turning the clutch mechanism is usually toast. with both of these systems one should also note whether the axle is turning inside the wheels when they are on the ground, the over running clutch sprags inside the drive gears could be stuck causing the wheels to turn without resistance applied, but stall when in contact with the ground.
while inspecting the trans axle note any wobble or free play in the axles or input shaft, this will indicate a worn case or bearing, resulting in a slipping gear in the trans axle.
Jul 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My snapper mower only has two forward gears and no reverse. the clutch is worn. Could replacing the clutch fix the problem or is there something else going on with the transmission?
Typically if your clutch is worn, you would experience some slippage in all gears. If your forward gears work, but reverse does not, you should be looking at a potentially more serious problem.
May 26, 2010 | Omega Rear Drive Wheel Snapper Mowers
Snapper won't go forward but will back
You're in luck, if your Snapper is of the type with a record player2.gif drive. Let me explain myself. Look under the motor. You should see that the shaft connects to a disc that has a rubber coated drive disc (or tire) under it. Works like this: when you are in the forward speeds, the tire is on one side of the disc. When in reverse, the tire moves to the other side. This means to me that it is neither your clutch or axle. Snapper dealers sell a tool that allows you to adjust the friction of the record (disc) against the drive wheel (tire). You loosen two allen screws on the disc where it mounts to the motor shaft, and the special tool screws into the center of the disc. With the tool installed, you screw down the jack screw to tighten the disc against the drive wheel. You then tighten the allen screws back up and you're done. Sounds too easy, 'eh? There are other variables you'll need to consider, mostly the condition of your drive wheel. The rubber on it will wear over time, so look at it carefully. If it is cracked or damaged, it should be replaced. It's easy to do. What about costs? Good question.... It's been a while, but best I remember, the speciality tool is ~$20. You'll need a long allen wrench to fit (~$2), and maybe the drive tire (~$15). The best news is that the speciality tool lasts virtually forever, and you'll use it again if you keep your Snapper
Jul 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
545 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
