Question about Panasonic Lumix DMC-FX01 Digital Camera
Buttons don't work and can't zoom
I had the same problem and did Guest's procedure. It fixed everything except the zoom! I can now take pictures and do everything except zoom. I'm guessing I "unfixed" the zoom mechanism when I put it back together. Before I try again I was wondering if anyone had any ideas. Thanks
  • 744 Answers
Hi
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u
rate me!!
Posted on Jul 26, 2009
The picture from the dvd is cut off at the top, bottom, and sides. only analog channels are found so zoom buttons on remote can't help. what to do? dvd player works fine on a different tv. this is a R
Check with an other known disc; have recording in aspect ration 4:3. If that disc show full screen picture, the recording to the present one; you're viewing has wide screen recording. Electro help
Nov 30, 2014 | RCA Televison & Video
Some buttons on my remote for my yamaha htr 5750 amp don't work. It's the original and was given to me. The volume and power buttons don't work or make the red lite flash; however the other...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 10, 2011 | Yamaha HTR-5750 Receiver
BATTERIES CORRODED, INFA RED NOT WORKING, BUTTONS NOT RESPONDING
"Batteries corroded"? That would seem to answer all the questions implicit in your post. Electrical contacts don't fare well from having batteries corrode on them. Clean the contacts and replace the batteries.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
What product?
Jul 20, 2011 | Audio Players & Recorders
I have a RAV254 remote for my Yamaha MODEL RX V457 6.1 Channel Receiver.... Everything works on it EXCEPT it will NOT power On or Off the receiver.... How do I fic this problem?????
Jul 11, 2011 | Audio Players & Recorders
MY CAMERA IS BROKE!!!!!!!!!!!!!
You will need to call Olympus Customer Service to discuss their repair policies and procedures. They will assist you to get the product repaired. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 20, 2008 | Olympus FE-170 Digital Camera
Unresponsive buttons because of engaged zoom
the reason why the lens zooms out is because the zoom switch is faulty and might need replacing.The way to tell this is when you switch it on in camera mode you will see the zoom bar displays on the lcd and stays there.
Jun 01, 2008 | Panasonic DMC-FX07 Digital Camera
Sony T5 Button Problems
Well if the repair was recent- you could send it back to be fixed properly at their expense -check them out but if no joy - new camera time
Jul 31, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Buttons stopped working
If yours still zooms in all the way when you turn it on, then I had a similar problem with mine. When I turned it on, the camera would zoom out all the way and the other buttons wouldn't respond. If I switched it to review, it would just cycle through all the pictures, so I figured somewhere the zoom lever was stuck inside. I don't know a lot about cameras, so I sent it in to Panasonic (it was still under parts warranty), but was informed that due to "grit substance" my warranty was voided and it would cost $179 to repair. Since I could buy the same camera used at www.keh.com for that price I told them to send mine back and I'd take a shot at fixing it (since I was pretty sure it was a mechanical problem). Here's what I did with a $1.79 glass repair screwdriver. Remove the battery and take out all the visible screws on the outside (2 on the right, 1 on the left, 3 on the bottom). Lift the back panel at the bottom edge, and it should pivot along the top edge until you can remove the back. Then unplug the two ribbon cables (the small one has a latch on top and the larger one has a black latch on the side that you need to lift). BOTH have hinges, not just the smaller one like other posts have said. Next you need to remove the front panel. There are three silver screws placed around the lens unit (look down inside, and you'll see them attaching it to the front panel). Remove these, and you should be able to remove the front (lift at the bottom and it pivots along the top edge). Now you should be able to pop off the top cover (with the zoom, power, etc). Now if you look at the bottom, there are two screws holding the board to the cover, remove these and you've got it apart. On the top right side of the board, you'll see where the external zoom switch pushes a very small black lever. This was where the problem with mine was, the black lever was stuck over. You can use the tip of the screwdriver to pop it back to the center position. Now make sure that if you push it one way or the other that it will recenter on its own. Mine didn't, so I had to pop the small silver cover off where the lever is with the flathead tip of the screwdriver. Be careful here. The lever just sits on a peg, and has very small gears that move a slide bar. If either of these fall, you may never find them again. I took both the lever and the slider off, cleaned them, and got it so it would recenter easily again. Then I put them both back in, popped the cover on (you may have to pry out one of the sides slightly to get it back on), and the lever works fine now. I wouldn't be surprised if your camera has this same problem. If it's something else, it's still probably a problem with this mechanism that you could fix. Anyways, reattach the board to the top cover, and pop it back onto the camera. Now insert the battery, and turn it on to see how it works. Even without the screen, you can try the zoom. If it all works, then all you need to do is put it back together in the opposite order you took it apart. When reattaching the LCD ribbon cables, make sure the hinges are open, insert the cable, and snap down its latch. Hopefully that works. I don't know much about cameras, but it wasn't too hard. Just work slowly and carefully.
Jul 12, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Fuji 4700 zoom
there is some chance that it's not getting power for the shutter release. Either becuase of some internal error on the switch, the circuit isn't closed, or that the batteries aren't performing. Unless you're tired of this camera, you could try with new, maybe borrowed, NiMH bats. Good luck
Jun 09, 2006 | Fuji FinePix 4700 Zoom Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
325 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
