Question about Maytag PYE2300AY Electric Dryer
Maytag dryer PYE2300AYW will not start
Attempted to use the dryer one day and it was just dead. I can hear the timer ticking, but the dryer is not coming on. What part should I try replacing?
    President:
  • 1,136 Answers
Hi, It sounds like the fuse inside the fryer might be bad. Here is a picture of the fuse.
Maytag dryer PYE2300AYW will not start - 20f01c3.gif To locate this fuse, insert a flat blade between the top and the front panel. There are 2 spring clips that will release the top. The heater and fuse are on the top rear of the drum. The fuse you willneed to test is #5 in the picture. If the fuse shows an open circuit, it will need replaced.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 26, 2009
Maytag pye2300ayw will not starte
You need to make sure that you have 220 volts to the dryer. If you do, then unplug the dryer. Lift the lid of the dryer by taking a putty knife and putting it under the lid of the dryer. There are two clips that you need to push in then the lid of the dryer will lift up. In the back left hand corner of the dryer, you will see the heating element. Beside that you will see a thermostat and thermal fuse. check both of them for continuity. Most likely the thermal fuse is bad. If it is bad replace it and clean your dryer vent. The thermal fuse breaks when the dryer gets too hot. It is a safety switch.
Oct 31, 2011 | Maytag PYE2300AY Electric Dryer
PYE2300AYW quit mid-cycle. Can hear the timer ticking but nothing is happening.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Maytag PYE2300AY Electric Dryer
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
1,458 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
