Question about Motorola Mobility RAZR V3x Cellular Phone
My RAZR will not power up however, there is a flashing blue light on the outside right corner. Why is this?
  • 34 Answers
Bala is correct. FYI, the blue light is the blue tooth indicator. You have the option turned on apparently.
Posted on Jul 26, 2009
  • 71 Answers
The IC is the problem.change the IC in service center
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
How do you turn these monitors on
theere is a touch area that has a depression in the lower right corner of the frame outside the screen, this is the on / off Button. when it powers up the controls and the on of button will be lighted, blue in color.
Dec 13, 2010 | Gateway FPD2275W LCD Monitor
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Strange symbol
any explained description u can give me ?
Jul 09, 2008 | Motorola Mobility RAZR V3
Blue light?
Sounds like you have the blue tooth on. I think that is what the blue light is for... The black screen I have no clue, i am sorry
Mar 03, 2008 | Motorola Mobility RAZR V3
Indicator unknown
the is the bluetooth icon.
Kinda looks like two side ways triangles stacked on top of eachother. GO into your settings and turn it off if you dont wantto use it. Bluetooth will drain a battery.
Jan 18, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 white screen problem
try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Nov 30, 2007 | Motorola Mobility RAZR V3
Blue screen on outside display screen
you need to have the LCD replaced on the mobile.
Jun 28, 2007 | Motorola Mobility RAZR V3
Any Help?
repair of the board may run up to $150...instead, search ebay for another unit (AS-IS) and use it for part swapping
May 28, 2007 | Toshiba Satellite A20 Notebook
Blue light on outside display 1/2 on.
The blue light indicates that BlueTooth is powered on. On my phone it flashes. You can turn it off by going to Settings - Connection - Bluetooth Link - Set up - Power. Select and change to Off.
Feb 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3x Cellular Phone Logo
167 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
