Question about Panasonic DVD-L55
Code h02 - Panasonic DVD-L55
  • 189 Answers
HI!
This kind of problem seems to be common on Panasonic. I understand it is linked to the spindle (motor) or optical block (laser).
Try the machine again and see if the disc is spinning as I have heard about many users giving the spindle a good spinning manually to fix the fault or giving the unit a good shake - STRANGE BUT TRUE!
I have a Panasonic NV-VP31 DVD/VCR combi which would not spin the disc so I tried a little spray of WD40 into the motor (where the shaft goes through and into the motor itself). I have had no more problems.
It may be that the unit will have to be taken apart for you get access to the spindle. If you are not good with a screwdriver find someone that is (DO NOT ATTEMPT IF YOU FEEL THAT YOU CANNOT DO THE JOB YOURSELF),
Fingers crossed and hope this helps :)
Posted on Jul 26, 2009
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 11, 2016 | Washing Machines
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
Dvd will not play. H02 appears. Have reset to no
H02 is a fault code, though I don't know what. It code be either an electrical fault or mechanical problem. A mechanical fault might be easy to spot so take off the top cover and see if anything is broken, otherwise I suggest a service manual will come in handy.
May 21, 2010 | Denon DVD-800 DVD Player
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
H02 code after inserting DVD
Hi,the spindle motor on the traverse deck of the laser is faulty.Replace it and the machine will function again.
Aug 14, 2009 | Panasonic Televison & Video
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
DVD-RV31 with H02 code
The Spindle motor is defective.
Feb 08, 2008 | Panasonic DVD-RV31 DVD Player
Panasonic DVD-L55 Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
