Question about Microsoft Xbox 360 Console
After xbox is turned on the screen is split in half?????
When I turn on the xbox 360 the disc loads up but the screen is split.. Their is a black line down the middle but clear picture on both sides.... Any suggestions!!
    President:
  • 1,179 Answers
I had this problem with my dvd player. It turned out the solution was to replace the cables. Once I used a new set of cables the problem vanished. This may work for you as well as if the cables get kinked or frayed at all it will not give an optimal connection. Hope this helps you out.
Posted on Jul 26, 2009
Got the game in dec wont play got a second game and it wont load said disc unrecanisable
You chould check your disc, when you get that error, it means that the disc is unreadable, lol. Which means it cannot be read, so you can\'t play your game.
Check the back of the game disc for scratches or dust/other that shouldn\'t be there.
Jan 14, 2013 | Activision Nascar The Game: Inside Line...
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
Black screen from downloaded xbox classic game
DO ANY OTHER GAMES YOU HAVE DO THE SAME THING ?
Jan 14, 2010 | Microsoft Xbox 360 Console
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Nov 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't load disc
It may be the disc..I used to have this same problem but it was because of the disc....sometimes it is the scanner inside the xbox but since all other games work it may be just your game disc
May 11, 2009 | Microsoft Xbox 360 Console
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont load...
cleaning the lens usually helps with this. If you don't have the tools to do it, try using a can of compressed air. If that doesn't work the laser may need to be replaced.
Dec 03, 2008 | Microsoft Xbox® 360 Core System Console
Disc wont play
i have the same prob my solution get a sony
Jul 01, 2008 | Microsoft Xbox 360 Console
Xbox360
Depending on the type of disc drive that you have in your Xbox 360 console, use one of the following methods:
Method A: Insert a straightened paper clip or another small, stiff wire into the first hole from the left side of the disc tray. To release the disc tray, push the paperclip into the hole to press the manual eject mechanism. The manual eject mechanism is a white lever that is visible behind the console casing. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method B: Insert a straightened paper clip or another small, stiff wire into the second hole from the left side of the disc tray. Push the paperclip repeatedly into the hole to turn a gear to release the disc tray. The hole is located about one-and-a-half inches (approximately four centimeters) from the left edge of the disc tray.
Method C: Insert a straightened paper clip or another small, stiff wire into the into the hole that is directly under the "X3" in the Xbox 360 label on the disc tray to release the disc tray. The hole is located about one inch from the right edge of the disc tray.
In each case, make sure that you line up the paperclip or stiff wire to pass through another notch behind the hole on the console casing.
Oct 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
219 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
